| » Bosch Dishwasher Model SHE44C06UC/22 doesn't fill |
Model Number: SHE44C06UC/22 Brand: Bosch Age: 1 - 5 years
My dishwasher will fill on the first cyle and run fine, after it drains it will not fill for any of the remaining cycles. I have switched out the control module and that didn't help. Anyone else run into this?
Quote:
Post the results. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 06-12-2012 at 05:22 PM. Reason: typo |
If I did this right... the volts went from 121 down to 51.
How long time it was reading 121 VAC?
Did the water go in while it was reading 121 VAC? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I believe it was reading 51 while it was trying to fill..It still filled on the first cycle and during that time it read 121.
If there is improper voltage then the problem very likely is a bad control board.
- The control board Part number: 676960 Gene.
__________________
Quote:
Also would not hurt to check the wires between the control board and the water valve.
__________________
I replaced the contol module and checked the wires...this time it made it through the first two wash cycles and didn't fill on the third cycle and did fill on the fourth cycle.
This is very strange and points to some harness or loose connections problem. This is the worst possible thing which is very hard to diagnose.
If you would not be able to diagnose it yourself, hire a pro. Good luck. Gene.
__________________
| Display Modes | |
| Bosch dishwasher repair manual? Model SHY56A05UC /14 | BoschSHY56A05UC/14 | Dishwasher Repair | 2 | 04-22-2012 02:41 PM |
| How to test a Bosch SHE... model dishwasher motor | wvomike | Dishwasher Repair | 2 | 03-15-2012 05:31 AM |
| Bosch Dishwasher (Model SHX46B05UC/14) is running 3+ hours... | pvan | Dishwasher Repair | 2 | 01-17-2012 10:23 AM |
| amana washer lw6501w2 won't fill, and Haier dishwasher model: esd310 has no power. | pjensen1 | Washer Repair | 0 | 11-03-2011 08:40 AM |
| Bosch Dishwasher model SHX43C05UC Died | Durango | Dishwasher Repair | 0 | 10-23-2010 09:34 PM |
