| » Whirlpool pressure problem |
Model Number: DU8900XY-1 Brand: Whirlpool Age: More than 10 years
Everything on the dishwasher works correctly, except the upper dish rack items do not get cleaned. It appears that the upper spray arm is not getting sufficient pressure to rotate. Both upper and lower arms spin freely.
I have taken the housing for impeller inside the washer tub apart as far as one can and have found nothing. The metal screen below the impeller is clean, as are all the parts where you can take out screws and inspect. Only two things seem to be potential answers -- The impeller blades are worn (do not really look bad) or the rubber seal for directing water to the upper arm is worn out. The rubber seal is quite flexible, but ???? Can anyone help? Or is the just an OLD dishwasher that needs to be replaced? Ads By Google Related Models |
| Display Modes | |
| Oven Pressure Regulator Replaced - new problem | tracy@aconnectivity.com | Oven Repair (including Ranges and Cooktops) | 3 | 02-12-2009 07:04 PM |
| Kenmore HE2T Error F20 with tub overfill problem is pressure switch | jaj_wis | Washer Repair | 0 | 02-04-2009 12:31 PM |
| Kenmore low pressure problem? | murdoc79rc | Dishwasher Repair | 1 | 02-04-2009 06:51 AM |
| water pressure problem | tony sullivan | Refrigerator & Freezer Repair | 1 | 05-14-2008 04:36 AM |
| High Pressure washer problem | sundance@hughes.net | General Talk | 0 | 03-13-2008 10:33 AM |
