| » GE Nautilus Fills with water, then won't run. |
Model Number: GSD2600G00ww Brand: GE Age: 5 - 10 years
I have a GE Nautilus dishwasher. When you turn it on it fills with water
and then won't run. As you turn the dial there will be a clunking sound as it hits each cycle, but nothing else happens if you leave the dial alone. (clunking sound comes from motor? pump? under dishwasher) It won't drain when you turn the dial, only fill. If you turn the dial manually, sometimes it will run if you turn the dial around the cycles three or four times. Ads By Google Related Models |
Remove the toe panel and check if the pump motor makes a humming noise when it should run. If it does, the best solution is to replace the pump & motor assembly. It comes with the installation instructions.
- The pump & motor assembly Part number: WD26X10013 Here are the breakdown diagrams and Replacement parts for General Electric GSD2600G00WW Dishwasher | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thank you for your advice. I noticed that I could not spin the shaft on the motor. Once I dissasmbled the pump and separated it from the motor, the motor worked fine. I ordered a new impeller and seal kit for the pump (part) (WD19X10032) and installed it. The motor shaft is no longer binding on the pump, and now the dishwasher works fine. I did not realize that the grater on the pump unscrews clockwise, and the impeller unscrews counterclockwise. I found this out after I took it apart. I coudn't find instructions on the forum on how to dissasemble the pump. Since I new that the grater was included in the impeller kit, I broke it to get it out (without damaging the pump housing). I wanted to make sure if the motor worked or not, before ordering parts. When I received the impeller kit it had instructions (I assumed it would). I also bought a lower rack to replace my rusted one. Thank you again for your contribution, and I will be buying more repair items from this company. Steve (SBR65) |
You are welcome Steve. I'm glad you were able to fix it and save some $$$. Good job!
Thank you for the feedback. Gene.
__________________
| Display Modes | |
| GE Nautilus won't drain - standing water | cherylbland | Dishwasher Repair | 1 | 03-28-2012 10:03 PM |
| GE nautilus dishwasher doesn't push water to top arm and won't drain | ole joe | Dishwasher Repair | 1 | 12-22-2011 10:43 AM |
| Water pouring out door of GE Nautilus | backyardhockey | Dishwasher Repair | 0 | 12-20-2011 11:48 AM |
| Nautilus Dishwasher Won't Fill With Water | MarcioDaCosta | Dishwasher Repair | 0 | 07-14-2010 06:25 AM |
| Water level does not shut off/ and it fills with water & drains but does not agitate | dogwood100 | Washer Repair | 1 | 04-14-2009 05:20 PM |
