| » Bosch dishwasher water inlet leak (with video!) |
Model Number: SHU43C05UC/46 Brand: Bosch Age: 1 - 5 years
I inherited this Bosch dishwasher but I'm not able to figure out how to stop the it from leaking water out of the top of the water inlet on the fill cycle. I took a video of what was happening to show exactly how it happens. What could be causing this?
Bosch Dishwasher Water Inlet Leak - YouTube Ads By Google Related Models |
Hi.
The water inlet system should be replaced Part number: 263833 Check the Q and A. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
It's got to be a restriction in the water inlet system witch caused the overflowing.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 06-07-2012 at 10:54 AM. |
I'm curious; did you watch the video? The water is flowing through the inlet assembly and into the bluish float assembly. If there is a restriction, wouldn't it be from the float assembly forward? Wouldn't this back up the water in the inlet assembly?
It turns out that the access valve (water inlet valve) is exactly what the issue was. Once the valve was replaced the water level was correct and there was no overflowing. There was no restriction in the water inlet system "which caused" the overflowing. There was simply too much water getting in. There is an internal diaphragm to the water valve that regulates water flow; this diaphragm was not functioning as designed. $36 part versus an $80 part.
Thank you for very helpful information.
Simon.
__________________
| Display Modes | |
| Bosch Dishwasher Water Inlet System Leaking | ontariogrey1980 | Dishwasher Repair | 3 | 10-29-2011 02:32 AM |
| water leak at inlet assembly/gasket on left side | Jerryreamer2 | Dishwasher Repair | 0 | 09-02-2010 07:21 AM |
| Water Inlet Leak? | johnsweaver | Dishwasher Repair | 3 | 08-12-2010 01:31 PM |
| Bosch Dishwasher Water Inlet System | BillyMac126 | Dishwasher Repair | 5 | 01-17-2010 05:48 PM |
| Bosch Dishwasher Inlet Leak? What is this part? | jakub | Dishwasher Repair | 1 | 03-10-2009 07:02 AM |
