| » Dishwasher stuck on cycle |
Model Number: GU1500XTLS2 Brand: Whirlpool Age: 1 - 5 years
For some time my dishwasher has been making a groaning sound but it always went through all of it's cycles. Recently it will run until it gets to 42 on the timer and stop. The first time I noticed this I opened the door and the heating element was glowing red. So far I have found that if I add water during the cycle the groaning stops and it sounds normal. I checked the float and it isn't stuck. I took the fill valve out and apart and cleaned the little screen. It is clear that not enough water is getting to the tub. Even after I added water it would not advance cycles. I even added boiling water to make sure it was hot enough. My heating element seems to be working because it will cause a quick blister if you touch it. I would really like to narrow the problem down before I start throwing parts at it.
Here are your parts.
Replacement parts for Whirlpool GU1500XTLS2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Sounds like you have narrowed it down to a fill problem. Since you are getting some water and have cleaned the fill valve filter screen, I would replace the fill valve. I am assuming that you are sure that the plumbing for the hot water to the unit is OK and there is sufficient flow.
__________________
| Display Modes | |
| Kitrchen Aid dishwasher stuck in cycle | moish3553 | Dishwasher Repair | 1 | 04-29-2012 09:16 AM |
| Jenn-Air Dishwasher stuck during cycle | octus | Dishwasher Repair | 1 | 12-14-2010 11:06 AM |
| Dishwasher stuck on wash cycle | Bunnyhop | Dishwasher Repair | 0 | 12-18-2009 07:13 AM |
| dishwasher getting stuck in rinse cycle | MoKirk | Dishwasher Repair | 0 | 10-25-2009 02:39 PM |
| Dishwasher gets stuck in cycle | woodieb1 | Dishwasher Repair | 4 | 05-10-2008 07:44 PM |
