Dishwasher will not dry
Dishwasher Repair
The dishes are clean, but they are not completely dry and sweat remains on door and bottom and sides of
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher will not dry
  #1 (permalink)
Old 09-11-2009, 07:49 AM
Junior Member
Betty350 is on a distinguished road
Default Dishwasher will not dry
Model Number: 66515919001   Brand: Kenmore   Age: 1 - 5 years
The dishes are clean, but they are not completely dry and sweat remains on door and bottom and sides of dishwasher after cycle is done.
Related Models
Kenmore 66515919001 DISHWASHER
Kenmore 66515922000 DISHWASHER
Kenmore 66515922001 DISHWASHER
Kenmore 66515923000 DISHWASHER
Kenmore 66515923001 DISHWASHER
Kenmore 66515924000 DISHWASHER
Kenmore 66515924001 DISHWASHER
Kenmore 66515929000 DISHWASHER
Kenmore 66515929001 DISHWASHER
Kenmore 66515932000 DISHWASHER
Kenmore 66515933000 DISHWASHER
Kenmore 66515934000 DISHWASHER
Kenmore 66515937000 DISHWASHER
Kenmore 66515939000 DISHWASHER
Kenmore 665159450 HOME GYM
Kenmore 66515952000 DISHWASHER
Kenmore 66515953000 DISHWASHER
Kenmore 66515954000 DISHWASHER
Kenmore 66515955790 DISHWASHER
Kenmore 66515955791 Dishwasher
Kenmore 66515955792 Dishwasher
Kenmore 66515955794 DISHWASHER
Kenmore 6651595840 DISHWASHER
Kenmore 66515958790 Dishwasher
Kenmore 66515958791 Dishwasher
Kenmore 66515958792 Dishwasher
Kenmore 66515958794 DISHWASHER
Kenmore 66515959000 DISHWASHER
Kenmore 6651596080 SF22-502-OVERFILL CONDITION
Kenmore 66515962990 Dishwasher
Kenmore 66515962992 DISHWASHER
Kenmore 66515964990 DISHWASHER
Kenmore 66515964992 DISHWASHER
Kenmore 6651596580 DISHWASHER
Kenmore 6651596581 Dishwasher
Kenmore 66515969990 DISHWASHER
Kenmore 66515969992 DISHWASHER
Kenmore 66515972990 DISHWASHER
Kenmore 66515972991 DISHWASHER
Kenmore 66515972992 DISHWASHER
Kenmore 66515973990 DISHWASHER
Kenmore 66515973991 DISHWASHER
Kenmore 66515973992 DISHWASHER
Kenmore 66515974990 DISHWASHER
Kenmore 66515974991 DISHWASHER
Kenmore 66515974992 DISHWASHER
Kenmore 66515979990 DISHWASHER
Kenmore 66515979991 DISHWASHER
Kenmore 66515979992 DISHWASHER
Kenmore 66515982990 DISHWASHER
Kenmore 66515983990 DISHWASHER
Kenmore 66515984990 DISHWASHER
Kenmore 66515987990 DISHWASHER
Kenmore 66515989990 DISHWASHER
Kenmore 66515992400 DISHWASHER
Kenmore 66515992401 DISHWASHER
Kenmore 66515994400 DISHWASHER
Kenmore 66515994401 DISHWASHER
Kenmore 66515999400 DISHWASHER
Kenmore 66515999401 DISHWASHER
Kenmore 66516002400 DISHWASHER
Kenmore 66516002401 DISHWASHER
Kenmore 66516003400 DISHWASHER
Kenmore 66516003401 DISHWASHER
Kenmore 66516004400 DISHWASHER
Kenmore 66516009400 DISHWASHER
Kenmore 66516009401 DISHWASHER
Kenmore 66516012400 DISHWASHER
Kenmore 66516012401 DISHWASHER
Kenmore 66516012402 DISHWASHER
Kenmore 66516012403 DISHWASHER
Kenmore 66516013400 DISHWASHER
Kenmore 66516013401 DISHWASHER
Kenmore 66516013402 DISHWASHER
Kenmore 66516013403 DISHWASHER
Kenmore 66516014400 DISHWASHER
Kenmore 66516014401 DISHWASHER
Kenmore 66516014402 DISHWASHER
Kenmore 66516014403 DISHWASHER
Kenmore 66516019400 DISHWASHER
Kenmore 66516019401 DISHWASHER
Kenmore 66516019402 DISHWASHER
Kenmore 66516019403 DISHWASHER
Kenmore 66516022400 DISHWASHER
Kenmore 66516022401 DISHWASHER
Kenmore 66516022402 DISHWASHER
Kenmore 66516022403 DISHWASHER
Kenmore 66516023400 DISHWASHER
Kenmore 66516023401 DISHWASHER
Kenmore 66516023402 DISHWASHER
Kenmore 66516023403 DISHWASHER
Kenmore 66516024400 DISHWASHER
Kenmore 66516024401 DISHWASHER
Kenmore 66516024402 DISHWASHER
Kenmore 66516024403 DISHWASHER
Kenmore 66516029400 DISHWASHER
Kenmore 66516029401 DISHWASHER
Kenmore 66516029402 DISHWASHER
Kenmore 66516029403 DISHWASHER
Kenmore 66516032400 DISHWASHER
Kenmore 66516032401 DISHWASHER
Kenmore 66516032402 DISHWASHER
Kenmore 66516032403 DISHWASHER
Kenmore 66516033400 DISHWASHER
  #2 (permalink)
Old 09-11-2009, 08:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Here is a tech sheet
I would check that the vent is opening.
If not, check the vent actuator for continuity.
Also check that the unit is draining properly, if water is left in the tub it cannot dry the dishes properly. Could be just a partially plugged drain.
If you use heated wash cycles and the machine runs normally the heating element and the high limit thermostat are probably OK.
If not check the heater for resistance and the thermostat, see the tech sheet.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
