| » MAH6500AWW ND CODE. Does not drain. |
Model Number: Mah6500aww Brand: Maytag Age: 1 - 5 years
My Maytag washer will not drain. I cleared the pump and found a piece of wire from an underwire bra in the impeller. I cleared it, but it will not operate. Everything else appears to work fine, spins etc. infact I finished a load by draining by gravity at the appropriate times.. I assume the pump is fried, but ow do I tell if it is the circuit board?
I would check to see if there is voltage to the pump during the drain cycle. If there is voltage to the pump during the drain cycle and the pump does not run then the pump is at fault and will need to be replaced. I have never had to replace a control board on one of these washers because the pump would not run.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| pf code won't drain | desanto | Dishwasher Repair | 1 | 02-18-2012 06:12 AM |
| maytag mah6500aww noise when spinning | hfamemail | Washer Repair | 2 | 01-17-2012 11:21 PM |
| MAH6500AWW unlocks door and won't start | LyleP | Dishwasher Repair | 0 | 01-12-2011 02:35 PM |
| MAH6500AWW replace boot instruction | appliance4me | Washer Repair | 7 | 11-29-2009 01:45 AM |
| Maytag MAH6500AWW | gazingm42 | Washer Repair | 7 | 08-24-2008 08:49 PM |
