Discuss
Dishwasher leaks from water inlet chamber overfill hole
 in
Dishwasher Repair
the water inlet chamber, AP2802392, has a pre-drilled hole on top of the chamber. During the fill cycles, water overflows
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher leaks from water inlet chamber overfill hole
  #1 (permalink)
Old 05-25-2012, 04:33 PM
Junior Member
Peter Daniel is on a distinguished road
Default Dishwasher leaks from water inlet chamber overfill hole
Model Number: SHY66C   Brand: Bosch   Age: 1 - 5 years
the water inlet chamber, AP2802392, has a pre-drilled hole on top of the chamber. During the fill cycles, water overflows and ends up in the plastic pan. There is a float in that plastic pan, and when enough water has collected, the float rises and activates the pump motor. But the water does not empty from the pan. you have to remove the water manually.
I posted the problem and your tech suggested to replace the pressure chamber AP3955009, which i did. that did not help.
I reduced the water inlet pressure. That did not help.
The dishwasher fills with water and does its job, as long as there is no water in the plastic catch pan below the stainless steel tub.
what do i have to do to stop the water inlet chamber from overflowing?
Related Models
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Amana SLD25M2G REF - SXS/I&W
Amana SLD25M2L REF - SXS/I&W
Amana SLD25M2W REF - SXS/I&W
Amana SLD25MB2L REF - SXS/I&W
Amana SLD25MB2W REF - SXS/I&W
Amana SLD25MBG REF - SXS/I&W
Amana SLD25MBL REF - SXS/I&W
Amana SLD25MBW REF - SXS/I&W
Amana SLD25MG REF - SXS/I&W
Amana SLD25ML REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) david465 Refrigerator & Freezer Repair 4 03-11-2010 05:12 PM
Dishwasher water inlet valve paulbedoyan Dishwasher Repair 0 06-13-2009 02:00 PM
Icemaker inlet leaks when water dispensed at door chann Refrigerator & Freezer Repair 0 04-08-2009 12:17 PM
Ice Machine water inlet "leaks". raterus Refrigerator & Freezer Repair 0 12-11-2008 06:26 PM
GE Dishwasher Water Inlet Valve Nino Hero Dishwasher Repair 2 02-29-2008 05:06 AM
