| » Frigidaire Dishwasher Leaks Hours After Cycle |
Model Number: FDB2410LDS1 Brand: Frigidaire Age: 5 - 10 years
Our 6 year old Frigidaire dishwasher just started leaking. It cycles and runs normally, but after a couple of hours there will be a small puddle underneath. It ends up being 1-2 cups of water throughout the course of the day/night.
I checked the visible connections & fittings during the run/drain cycle and everything was dry. By the end, the motor mount bracket was a little damp. I pulled everything from the inside and it looks good, but somehow the water that's left in the bottom of the tub is slowly leaking out over time. Would the next step be to pull it out to access the motor connection? I've attached a photo of where the water is dripping. Any ideas would be helpful. Thanks! Ads By Google Related Models |
It seems to me that the only place it could be leaking is at the O ring where the motor connects to the main housing. Would this be a common place for a leak?
That's the only place I can't see because the motor mount is in the way. Everything else seems dry. |
Yes that could be where it is leaking.
You may be able to narrow it down by using a small mirror and a flashlight. The mirror I am referring to is the type used by mechanics, like a dentist's mirror just larger. Or tape a small mirror at an angle onto a dowel ____/.
__________________
| Display Modes | |
| Bosch Dishwasher leaks at end of cycle | lancer01 | Dishwasher Repair | 2 | 03-22-2011 04:30 AM |
| Dishwasher Cycle Running for 3 hours | kweber | Dishwasher Repair | 0 | 04-25-2010 01:18 PM |
| Frigidaire DishWasher leaks from bottom | four2699 | Dishwasher Repair | 1 | 12-14-2009 06:34 AM |
| Whirlpool dishwasher taking 12+ hours to complete a cycle - please help! | becstar | Dishwasher Repair | 4 | 03-04-2009 11:26 AM |
| ge dishwasher leaks after cycle | hkocis | Dishwasher Repair | 0 | 11-23-2008 09:37 AM |
