| » circuit board short |
Model Number: mdb9150aws Brand: Maytag Age: 1 - 5 years
I have a maytag dishwasher and am having trouble with it completing a cycle. i can program it to start, but when it goes to start, the motor will give a quickspin (about 1/2 a turn) then it will stop. Then it will sit there and keep starting like i described until i cancel it or open the door. I pulled the circuit board out and it has two highly heated up resistors labeled R301 and R302. the circuit board is discolored at those connection sites. I realize i have to replace that, but the question is..... What made those resistors blow? ANY help will be appreciated ! ! !
Looks like the start relay is built into the circuit board (small blue box 1/2"x1")I do not know how to check it without specs on voltage....... the only other control is the overload switch.. Think that would do this?????
Thanks Phil |
Phil (Pillcotex):
Did you figure out what caused your dishwasher to go bad? I have almost the exact same model...a little older. I think the same resistors are burned. Just wondering if you were able to diagnose it. Thanks. |
Quick update...for my MDB9150AWW Maytag...I just installed a new control board this evening. Not too difficult. I made a picture of where the wires plug in before I removed the defective board. This was real helpful when putting the new board in.
Based on suggestions from others, I checked the wiring harness for defects. I found that there were a couple of wires where the plastic sheathing was cut through, but the copper wire looked unharmed. I found this down where the door hinges. It looks like a metal part from the door had been cutting into the wires somewhat. I'm not sure if this is what caused the control board to fail. Anyway, I used some electrical tape to tape up the wires, and then also to cover up and sharp metal edges. When I was all done, I turned the power back on. Works like new! It is now on it's 2nd wash cycle. |
| Display Modes | |
| Replacing control panel circuit board | vickie | Dishwasher Repair | 1 | 01-14-2008 03:51 AM |
| microwave circuit board | jmonroe | Microwave Repair | 0 | 12-06-2007 05:57 PM |
| Control Pad or Circuit Board Problem? | onegumshoe | Oven Repair (including Ranges and Cooktops) | 2 | 11-20-2007 05:15 PM |
| Refrigerator Circuit Board Replacement | hdlady | Refrigerator & Freezer Repair | 1 | 11-15-2007 09:48 PM |
| Circuit board replacement | tobrouhard | Refrigerator & Freezer Repair | 5 | 08-16-2007 06:24 AM |
