| » Maytag MDB9100AWB Doesn't Clean Well |
Model Number: Maytag MDB9100AWB Brand: Maytag Age: 5 - 10 years
I am hoping you guys can help me. I have an older Maytag MDB9100AWB dishwasher. For the past few years it hasn't been cleaning as well as I would like it to. The filter screens get clogged up quickly, it exhibits low pressure at the arms, soap door sometimes doesn't clear out like it should. So I take it apart, clean everything and it works (kind of) for awhile longer.
This time I started to do some more research and I found a link to a potential problem regarding stripped threads on the pump impeller. Well I don't think that's my problem but when I removed the bottom drain cover I noticed that there was no check ball under the drain cover. I am going to order one and put it in but do you think that could be part of my low pressure problem? I have enough water, the drain valve seems to work, I only see water at the garbage disposer during the discharge phase. It just seems like I have low pressure to the spray arms. Anyway any thoughts or advice you can give me would be appreciated. Thanks, Jeff Ads By Google Related Models |
| Display Modes | |
| Maytag (MDB9100AWB) not filling with water | MDB9100 | Dishwasher Repair | 6 | 03-10-2011 02:54 PM |
| Maytag does not clean very good!!!! HELP! | RodneyF | Dishwasher Repair | 0 | 07-16-2009 06:19 PM |
| Maytag oven won't clean | newguy | Oven Repair (including Ranges and Cooktops) | 0 | 09-03-2008 07:09 PM |
| maytag jet clean eq plus | meatball | Dishwasher Repair | 0 | 06-15-2008 04:35 PM |
| Maytag Dishwasher not getting dishes clean | fillhardfarm | Dishwasher Repair | 1 | 01-18-2008 12:49 PM |
