Discuss
No start problem related to float in Bosch DW
 in
Dishwasher Repair
Hello all, I have a Bosch SHE45M with a no start problem related to the float on the left side
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No start problem related to float in Bosch DW
  #1 (permalink)
Old 05-15-2012, 05:47 PM
Junior Member
jasper88 is on a distinguished road
Default No start problem related to float in Bosch DW
Model Number: SHE45M05UC   Brand: Bosch   Age: 1 - 5 years
Hello all,
I have a Bosch SHE45M with a no start problem related to the float on the left side of machine. The machine was working but had a small leak underside which ended up being the inlet connector. While I had it out I noticed there was a lot of gunk in the float assembly (the plastic assembly with a red cup, its opening down, with a red curved arm which actuates a microswitch) so i took it apart to clean it. I thought I got it back together properly, but the machine now won't start.
The power and water supply is on, and there is time displayed in the window, but the machine never runs (there is no water now in the float assembly, but there is some in the sump).
In going back to what I played with, I found that if I actuated the microswitch, the machine starts to run. This doesn't seem to make sense, since the microswitch is also connected to a rod pushed up by a float in the catch basin in the base of the machine. Logic would suggest that water in the bottom of the base would be a leak and should shut the machine off-not on.
So the only thing I can think of is - either I have some connector upside down, or - there has to be water in the trough where the red cup is to push the switch up (and I don't understand the purpose of the catch basin float in the bottom machine frame).
Can anyone explain how this works? I have a few photos, attached.
While we're at it, the door catch is extremely hard to open and close - is there an adjustment for this?
Thanx, Jasper
Ads By Google
Related Models
Whirlpool SHF3800W0
Whirlpool SHF3800W1
Whirlpool SHF3801W0
Whirlpool SHF3804W0
Whirlpool SHF3804W2
Whirlpool SHF4500W0
Whirlpool SHF5500W0
Whirlpool SHF5501W0
Whirlpool SHF5504W0
Whirlpool SHF5584P0
Whirlpool SHF5584P1
Whirlpool SHF5584P2
Whirlpool SHF5800W0
Whirlpool SHF5800W1
Whirlpool SHF5801W0
Whirlpool SHF5801W1
Whirlpool SHF5880P0
Whirlpool SHF5884P0
Whirlpool SHF5884P1
Whirlpool SHF5884P2
Whirlpool SHF6000W0
Whirlpool SHF6000W1
Whirlpool SHF6002W0
Whirlpool SHF7800W0
Whirlpool SHF7800W1
Whirlpool SHF7801W0
Whirlpool SHF7804W0
Whirlpool SHF7804W1
Whirlpool SHF7884P0
Whirlpool SHF7884P1
Whirlpool SHF7884P2
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30000
Whirlpool SHU30010
Whirlpool SHU30011
Bosch SHU3002
Whirlpool SHU30040
Whirlpool SHU30041
Bosch SHU3006
Whirlpool SHU30110
Bosch SHU3012
Whirlpool SHU30140
Whirlpool SHU30141
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
  #2 (permalink)
Old 05-16-2012, 03:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The cost of this part is just 11 bucks, so in such situation I would just replace this part.
- The pressure chamber Part number: 440670
Part number: 440670
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-16-2012, 04:58 PM
Junior Member
Default
Cheap enough, but does it have to be filled with water first to make the DW start running? Wouldn't want to start replacing parts to fix something (unfortunately, much too common these days). And it might not solve the problem? I'm trying to understand how it works.
  #4 (permalink)
Old 05-16-2012, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Based on the part name I'm assuming it works by a pressure. Also I don't think it had water when it left a plant.
This is a safety device to prevent overfill. It turns on the drain pump and turns off the water inlet valve as soon as it feels water in the base or the water over the level inside the machine.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Float Reset? Emos Dishwasher Repair 3 03-02-2011 11:36 PM
Bosch dishwasher float switch Steve A Dishwasher Repair 14 10-12-2009 07:33 PM
Kenmore Microwave -No Heat, No Turntable -Related? airheads Microwave Repair 2 07-14-2009 09:11 AM
