| » Kenmore Dishwasher leaks above motor |
Quote:
close the door hit the cancel button to pump out the excess water. then do your repair or call a tech. |
If this is a unit manufactured by whirlpool with a horizontal mounted motor, the problem is most likely caused by a leaking motor seal. Once the seal leaks, water wil start dripping onto the floor and some will migrate into the motor bearing causing the bearing to rust and eventually stop. Once the bearing is bad, it will be very noisy and the only solution is to replace the motor or replace the dishwasher.
If you find out that the seal is leaking and the motor still sounds fine, repace the seal immediately. You can buy the seal kit below Part number: 8193510 There are several other places that sell this kit but they are a little more expensive. Good luck. Last edited by Adam / APP Team : 08-01-2012 at 04:13 PM. Reason: Advertising ******** |
| Display Modes | |
| Amana Dishwasher leaks from above motor pump assembly | oakland1000 | Dishwasher Repair | 4 | 11-22-2011 06:03 PM |
| kenmore dishwasher leaks | eazye91 | Dishwasher Repair | 0 | 07-19-2009 05:47 PM |
| Kenmore Ultra Wash III Dishwasher leaks | Ricarno | Dishwasher Repair | 0 | 06-27-2009 12:43 PM |
| Kenmore Ultra Wash III Dishwasher leaks | Ricarno | Dishwasher Repair | 0 | 06-27-2009 11:06 AM |
| kenmore dishwasher leaks | barneyrubble | Dishwasher Repair | 3 | 06-18-2009 10:38 PM |
