| » Bosch Dish washer will not finish drain cycle |
Model Number: SHX33A05UC/14 Brand: Bosch Age: 5 - 10 years
My bosch dishwasher will not complete drain cycle. When I try to run diagnostics nothing happens. After cleaning out the filters and replacing the drain float I am still having the same issue. The dishwasher runs with door open and will not complete drain cycle. I am trying to see if I can remove the control panel but I cant seem to get it loose. Any guidance and help trouble shooting this would be greatly appreciated.
~Mike Ads By Google Related Models |
Check the connection where the drain pump connects into the sink/disposal. If you hear it trickling into your sink, it's going to be a restriction in the pump to the sink. If you have a splitter to make the hose bigger to fit into your disposal, this is more than likely your issue.
After viewing one to many you tub video's. I decided to take apart the front cover and take a peak at the control panel circuit board. I found a bernt mark on the green board that inicated failure. So I ordered a new one. Recieved it in 24 hrs plugged it in. Rehooked everything back up and good as new. Thanks to all.
| Display Modes | |
| Dish washer drain cycle wont complete | warren3076 | Dishwasher Repair | 0 | 11-20-2011 10:02 PM |
| Washer wont drain/finish cycle without force. | wendysuebee | Washer Repair | 1 | 03-23-2011 06:59 PM |
| water does not drain after finish cycle | narendra patel | Dishwasher Repair | 0 | 07-22-2009 10:31 AM |
| Kenmore/Whirlpool Dishwasher won't finish drain cycle | grisatre | Dishwasher Repair | 0 | 03-21-2009 10:27 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
