| » Whirlpool heavy duty extra large capacity plus washier |
Hi.
Please describe more detailed how the agitator acting and also provide the model number. Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
The model number is LXR9245EQ2.
At first the agitator was making a clicking noise like you could tell it was stuck. It's not making that noise but it's now not really moving at all. I can move it by hand freely but it doesn't did it on it's own. |
Hi.
Is it the top portion of the agitator you are talking about or the hole agitator? Simon.
__________________
Hi.
Pry off the the top cap, remove the 7/16 bolt and pull out the agitator. Turn the washer on and check if the transmission shaft is moving and you can't stop it by hand. If the shaft is OK - replace the agitator base. If not - transmission. The agitator base Part number: 3350830 The transmission Part number: 3360629 Here are the breakdown diagrams and Replacement parts for Whirlpool LXR9245EQ2 AUTOMATIC WASHER | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Hi.
Now it's completely different picture. The problem is with so called "agitator dogs". They are located inside the agitator between upper and lower part. The agitator dogs Part number: 80040 Use the video clip for the instructions. Good luck. Simon.
__________________
| Display Modes | |
| whirlpool ultimate care II Heavy duty su[er capacity plus | PeggyO'brien | Dryer Repair | 1 | 08-03-2011 03:44 AM |
| Need Help Whirlpool Heavy Duty Extra Large Cap. Plus | chachi0805 | Washer Repair | 2 | 02-11-2011 11:13 AM |
| Kenmore elite heavy duty king side capacity | bigal | Washer Repair | 0 | 03-18-2009 01:59 PM |
| Kenmore elite heavy duty king side capacity | bigal | Washer Repair | 0 | 03-18-2009 01:46 PM |
| Heavy duty extra large capacity two speed | angelo | Washer Repair | 7 | 01-08-2009 04:49 PM |
