| » nothing is working |
Model Number: kuds02srss2 Brand: Kitchen Aid Age: 5 - 10 years
there are no lights lit up, i bypass the latch swicth,still no lights, i check the ribbon cable attached to the control panel and there are black marks in a few ribbon that cannot be cleaned off. do you think it could be the ribbon or the circuit board . i brought this used cheap $15.00 and the seller said it only needed a drain pump. i like to fix this but not sure if it is worth putting 150.00 into it any suggestions
Hi.
Locate the thermal fuse at the control board and check if it's open (using the multimeter). The fuse Part number: W10258275 Here are the breakdown diagrams and Replacement parts for Whirlpool KUDS02SRSS2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Check if the unit is getting 120VAC at the junction box, at door latch and at the control board. Simon.
__________________
| Display Modes | |
| Ice Maker not working, water dispenser is working fine | Monique | Refrigerator & Freezer Repair | 43 | 08-21-2012 09:18 PM |
| Dryer panel not working. 2 low amber lights on constant. Light inside working. | tsgibson | Dryer Repair | 1 | 12-28-2011 06:39 AM |
| refrigerator stopped working cleaned it and started working then stopped working agai | ravaginggoatman | Refrigerator & Freezer Repair | 5 | 12-18-2010 01:13 AM |
| Microwave stop working, light and clock working | ketan | Microwave Repair | 0 | 07-09-2009 04:43 PM |
| Moved dishwaher was working perfect, put it back in now not working? | VickyRN | Dishwasher Repair | 3 | 08-15-2008 08:34 AM |
