| » Fridgidaire dishwasher does not drain |
Model Number: GLD2875FPW2 Brand: Frigidaire Age: 1 - 5 years
Had this dishwasher about 3 years. Stopped draining yesterday. It is absolutely silent during the time that it would normally drain. (At the beginning presumably since it has sitting water.) Can I assume it isn't a drain issue and is either drain pump or control panel?
Replacement parts for Frigidaire GLD2875FPW2 DISHWASHER | AppliancePartsPros.com Here is the tech sheet http://manuals.frigidaire.com/prodin.../154495501.pdf Can I assume it isn't a drain issue and is either drain pump or control panel? I would also conclude this since it is totally silent during a drain cycle. Check the power at the pump when it should be draining. If you have 120 volts and the pump is not running then the pump is toast. If there is no power then it is the control board or the wiring from the control board to the pump.
__________________
| Display Modes | |
| Fridgidaire FDB710LCS0 dishwasher | cranford.benjamin | Dishwasher Repair | 1 | 03-31-2012 04:03 AM |
| Fridgidaire Dishwasher cl code but switch working | CaptnDale | Dishwasher Repair | 4 | 07-17-2011 07:46 PM |
| Fridgidaire dishwasher dial | KayAnn | Dishwasher Repair | 3 | 09-26-2010 04:49 PM |
| fridgidaire dishwasher motor | nadake | Dishwasher Repair | 0 | 09-23-2009 09:16 PM |
| Fridgidaire Dishwasher Dead | mustbecrazy | Dishwasher Repair | 0 | 06-05-2009 04:28 PM |
