Discuss
No water going to upper arm, and therefore doesn't rotate
 in
Dishwasher Repair
I have a Bosch SHU5315. During a cycle, the upper arm doesn't rotate, and no water comes out of the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No water going to upper arm, and therefore doesn't rotate
  #1 (permalink)
Old 04-23-2012, 10:55 AM
Junior Member
lmcrulu is on a distinguished road
Default No water going to upper arm, and therefore doesn't rotate
Model Number: SHU5315   Brand: Bosch   Age: More than 10 years
I have a Bosch SHU5315. During a cycle, the upper arm doesn't rotate, and no water comes out of the upper arm. Therefore, the top half of my dishes never get washed. I have already done the following:
1. Thoroughly cleaned the filter.
2. Made sure that there was no debris in the lower and upper arms. (Debris free).
Any help would be appreciated...
Thanks.
Related Models
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55010 Dishwasher
Whirlpool SHU55040 Dishwasher
Whirlpool SHU55042 Dishwasher
Whirlpool SHU60020 Dishwasher
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70010 Dishwasher
Whirlpool SHU70041 Dishwasher
Whirlpool SHU70050 Dishwasher
Whirlpool SHU70051 Dishwasher
Whirlpool SHU70052 Dishwasher
Whirlpool SHU75010 Dishwasher
Whirlpool SHU75042 Dishwasher
Whirlpool SHU80010 Dishwasher
Whirlpool SHU80041 Dishwasher
Whirlpool SHU80042 Dishwasher
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90002 Dishwasher
Whirlpool SHU90041 Dishwasher
Whirlpool SHU90050 Dishwasher
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99041 Dishwasher
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99052 Dishwasher
Whirlpool SHU99053 Dishwasher
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A WASHER-TOP LOADING
Hoover SHWA2501W WASHER-TOP LOADING
Hoover SHWA2506A WASHER-TOP LOADING
Hoover SHWA2506AT WASHER-TOP LOADING
Hoover SHWA2506W WASHER-TOP LOADING
Hoover SHWA2506WT WASHER-TOP LOADING
Hoover SHWA2507V WASHER-TOP LOADING
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
  #2 (permalink)
Old 04-23-2012, 05:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the circulation pump work? Does the lower spray arm rotate?
What is the end of the model number?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-23-2012, 07:40 PM
Junior Member
Default
Hi Gene,
Does the circulation pump work? Does the lower spray arm rotate? Yes to both. However, I opened the door, stuck a screwdriver into the top latch, and pressed the start button. This way I was able to see what was happening inside with the door opened. This is what I saw:
The lower arm was rotating, but rather slowly, and water was coming out, but was only about 3-4 inches high.
I also did the following (with the washer door open, screwdriver into the top latch, and pressed the srart button):
1. I removed the lower arm, the water was coming out of the center, but only about 2 inches high.
2. With the lower arm removed, I put my hand to cover the center flow. Water then started coming out of the top arm, but barely any rotation.
One additional thing that I did was run the diagnostic test (found a manual on the web which described how to do this). The result was that a Fault code = 2 was displayed. Fault code 2 = Heating Fault.
Therefore, I am starting to believe that the washer probably has multiple problems.
What is the end of the model number? The complete model number is the following: SHU5315UC/U11 (FD8005 05 0149)
Thanks again for you help.
Rui.
  #4 (permalink)
Old 04-24-2012, 02:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Rui,
Sounds like the circulation pump does not create enough pressure. It can be because of not enough water in the dishwasher or a bad circulation pump.
Check the water level inside the dishwasher while it's in a middle of the wash cycle. If it seems less than it suppose to be, add a few cups of water to see if it will make any difference. Post the results.
__________________
  #5 (permalink)
Old 04-24-2012, 06:02 PM
Junior Member
Default
Hi Rui,
Hi Gene,
I did as you asked. I did the following:
1. Started the machine on "Delicate/Econo". Observation: Cycle Countdown started at "2H". If I recall, usually it would start at 76 minutes or so.
2. After 30 minutes or so, I added water (about 12-14 cups). I added water to make sure that the water covered the top of the filter cup in the center. I also put a screwdriver to the latch and pressed the start button to observe what was happening inside the machine. Observation: Same as before (yesterday), only the lower arm was rotating with about 4.5 inches of water or so. (No water being pumped to the upper arm). It looks like this time a little bit more water was being pumped out of the lower arm than yesterday because with the door open, when I was observing, the pressure did allow some water to come out through the sides of the open door, but it was minimal.
Let me know if you want me to try something else.
Thanks again for your help.
Rui.
  #6 (permalink)
Old 04-24-2012, 07:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Rui,
Looks like there are two problems: a bad circulation pump (insufficient pressure) and a bad control module (2H display).
- The circulation pump Part number: 239144
Part number: 239144
- The control module Part number: 266746
Part number: 266746
__________________
  #7 (permalink)
Old 04-24-2012, 08:43 PM
Junior Member
Default
Rui,
Part number: 239144
Part number: 266746
Hi Gene,
Thanks for your response and analysis. It is really appreciated!. Gene, I have one more question before I order the parts.
In my earlier post, I mentioned that I ran a self-diagnostic test and received a Faut code = 2. Fault Code 2 = Heating fault. Also, I noticed that the water does not really get hot either. Do you think that I need the heater assembly part (AP2802450 - BOSCH 480317 Heater Assembly, for Aqua Sensor (softer Bearing), Sh, AP2802450 | AppliancePartsPros.com), or any other part to address the Fault code =2 issue? Or will the control module that you mentioned address this as well.
Looking forward to your reply, and thanks again for your help!
Best Regards,
Rui.l
  #8 (permalink)
Old 04-26-2012, 02:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by lmcrulu View Post
...In my earlier post, I mentioned that I ran a self-diagnostic test and received a Faut code = 2. Fault Code 2 = Heating fault. Also, I noticed that the water does not really get hot either. Do you think that I need the heater assembly part (AP2802450 - BOSCH 480317 Heater Assembly, for Aqua Sensor (softer Bearing), Sh, AP2802450 | AppliancePartsPros.com), or any other part to address the Fault code =2 issue? Or will the control module that you mentioned address this as well...
Hi Rui,
In most cases such heating faults caused by a faulty control module. So, I hope the new control module will fix it as well.
__________________
  #9 (permalink)
Old 04-30-2012, 08:49 AM
Junior Member
Default
Hi Rui,
Hi Gene,
Thanks for the info. Once I change the parts I will report back and let you know how it went.
Thanks for your help.
Rui.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Dishwasher upper spray arm does not spray and rotate. UtilaBob Dishwasher Repair 1 06-02-2010 03:22 AM
Front load washer drum won't rotate once it fills with water christizie Washer Repair 2 03-04-2010 03:46 AM
Upper spray arm does not rotate btd Dishwasher Repair 4 06-24-2009 08:08 PM
No water to upper spray arm dheckcntfxit Dishwasher Repair 0 01-15-2009 10:08 AM
No water in upper spray arm caveman Dishwasher Repair 0 02-12-2008 08:03 AM
