Discuss
Seeking diagnostics advice for Whirlpool Quiet Partner IV
 in
Dishwasher Repair
Ran into what appears to be a common issue with my dishwasher: It stopped washing mid-cycle with a dead control
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Seeking diagnostics advice for Whirlpool Quiet Partner IV
  #1 (permalink)
Old 04-22-2012, 06:08 PM
Junior Member
Broding is on a distinguished road
Question Seeking diagnostics advice for Whirlpool Quiet Partner IV
Model Number: GU2475XTVB0   Brand: Whirlpool   Age: 1 - 5 years
Ran into what appears to be a common issue with my dishwasher: It stopped washing mid-cycle with a dead control panel (no illuminated LEDs, no response to button pushing). After verifying that the thermal fuse had not blown and 120VAC was present at the control board, I was stumped.
I found a post in the forums (Whirlpool DU1055XTVSO is currently dead.) that had a recommended diagnostic procedure to test whether the control board or the control panel had a fault, though it was for a different model. The test indicated that the control board was the problem (drain did not turn on after pulling ribbon from control board and did not see 120VAC between CON1 P4 and CON2 P6).
Because the control board in the referenced post looked essentially identical to mine, I assumed it was good enough and ordered a new control board. However, after replacing it, nothing changed. Still zero voltage between CON1 P4 and CON2 P6, no response or illuminated LEDs on the control panel.
I'm not sure where to go from here. I've checked for continuity on each of the door switches and they appear to be normal (black-white and tan has 3VAC when open, zero when closed?). It appears that there are some test pads on the control board for the control panel ribbon connector, but I can't find anything online regarding the test process.
Any suggestions for next steps are appreciated - thanks in advance!
Related Models
Whirlpool GU2475XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY0 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY1 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY2 UNDERCOUNTER DISHWASHER
Whirlpool GU2475XTVY3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT1 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT6 UNDERCOUNTER DISHWASHER
Whirlpool GU2500XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2548XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT1 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT6 UNDERCOUNTER DISHWASHER
Whirlpool GU2600XTPT7 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTST0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTST1 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSY0 UNDERCOUNTER DISHWASHER
Whirlpool GU2700XTSY1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVS0 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVS1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVS2 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVS3 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVT0 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVT1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVT2 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVT3 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVY0 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVY1 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVY2 UNDERCOUNTER DISHWASHER
Whirlpool GU2800XTVY3 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXB0 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXB1 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXB2 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXB3 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXQ2 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXS0 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXS1 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXS2 UNDERCOUNTER DISHWASHER
Whirlpool GU3000XTXS3 UNDERCOUNTER DISHWASHER
Whirlpool GU3100XTVB0 24" ADA UNDERCOUNTER DISHWASHER
Whirlpool GU3100XTVQ0 24" ADA UNDERCOUNTER DISHWASHER
Whirlpool GU3100XTVS0 24" ADA UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPB4 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPB5 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPQ4 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPQ5 UNDERCOUNTER DISHWASHER
Whirlpool GU3200XTPS0 UNDERCOUNTER DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool quiet partner 1 kryonker Dishwasher Repair 0 02-29-2012 12:08 PM
Whirlpool quiet partner III PeterK Dishwasher Repair 0 08-14-2011 06:26 PM
Whirlpool Gold Quiet Partner - Diagnostics deafunderstanding Dishwasher Repair 0 03-03-2011 09:11 AM
Whirlpool Quiet Partner 1 subr Dishwasher Repair 2 02-16-2011 03:55 PM
Whirlpool Quiet partner II rsnyder1976 Dishwasher Repair 0 12-16-2010 06:28 AM
