| » Leaking Dishwasher (diverter motor) |
Model Number: 665.13922K010 Brand: Kenmore Age: Less than 1 year
I have a rather newish Kenmore Elite 665.13922K010. It has been leaking from the diverter motor, W10056349, which has been replaced by W10155344. The problem is the seal that the diverter motor rests against, which basically a 3/4" rubber washer with a spring behind it. I just ordered a replacement diverter motor, but I can't see that the seal is included; the exploded diagram didn't have a complete breakout.
Q: Is the seal included? Ads By Google Related Models |
Hi.
I am having the same problem. The description doesn't specify what is included, but because that seal isn't listed separately most likely it's included. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Home appliances are really made like "chit" these days. |
Quote:
The seal is incorporated into the sump housing. See Part number: AP4324823
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices. Thank you for supporting our free repair help forum. |
We have run the dishwasher twice now, and all is perfectly dry; I have a flat piece of cardboard slid beneath the center of the dishwasher.
The fix: I sparingly smeared a light lubricant around the rotating shaft that fits through the center of the seal to prevent the silicone from sticking to it. Then I spread automotive silicone carefully around the neck that supports the rotating shaft of the diverter motor and rests against the face of the seal. I also spread silicone on the face of the seal to insure good adhesion between the two pieces. I let it dry overnight. |
Quote:
If you need anything else please let us know. Thank you for choosing AppliancePartsPros.com.
__________________
I had the same problem with a leaking diverter motor (actually not even functioning) and leaking around the sump seal. To fix this problem, I bought a new diverter. The leads for the diverter motor were so corroded on one set of wire terminals that I had to take apart the diverter motor and solder the wires right to the diverter switch terminals....keeping polarity intact with the wires. I did not know where find a new terminal connector for the wires. The more important part was the seal. It CAN be removed from the bottom of the sump on the Kitchenaid dishwashers just by popping it out with a screwdriver. I then used some silicone plumbers grease and coated it very well and pressed it back into place. Reinstalled the motor and hooked it back up. Works like a champ now. The design is a poor one and it seems hot water will eventually melt out the grease seal. I always wondered why the dishes weren't getting clean any longer and didn't associate that with a failed diverter motor.
Thank you for shearing you experience with us.
Simon.
__________________
| Display Modes | |
| diverter | mary84b9 | Washer Repair | 0 | 03-01-2011 06:48 AM |
| Frigidaire Dishwasher - Checkball/Water Diverter Not Functioning | Paavo007 | Dishwasher Repair | 14 | 01-24-2011 11:35 AM |
| Dishwasher leaking water from motor area | thenefas | Dishwasher Repair | 2 | 11-04-2010 06:55 AM |
| Air diverter? | FFMikeM | Dishwasher Repair | 0 | 06-14-2009 09:04 AM |
| Dishwasher is leaking water around motor | davesob | Dishwasher Repair | 1 | 11-07-2008 08:43 AM |
