| » My dishwasher will not fill w? water |
Model Number: MDB500AWB Brand: Maytag Age: 5 - 10 years
My Matag DW will not fill with water I filled it fm the sink once and it did fine but the last time it did not do a rinse and I had soapyness
Hi.
With toe panel removed check if the float (located in the front left corner) is not stocked in upper position and see if the water level switch is OK. Next, using the multimeter, with timer set for "fill" check for 120VAC at the water inlet valve contacts. If there is the 120v to the valve and the float switch is closed - replace the valve. The float Part number: 99002363 The water level switch Part number: 99002560 The water inlet valve Part number: 99001359 Her are the breakdown diagrams and Replacement parts for Maytag MDB5000AWB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com Thank you. post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Dishwasher won't fill with water | Tru2Chevy | Dishwasher Repair | 5 | 12-21-2011 05:23 AM |
| Dishwasher won't fill with enough water | andersjb | Dishwasher Repair | 1 | 11-15-2009 02:06 AM |
| dishwasher does not fill with water | christo_john | Dishwasher Repair | 0 | 08-30-2009 03:39 PM |
| Dishwasher won't fill water | Jolangl2 | Dishwasher Repair | 1 | 08-21-2009 02:57 PM |
| Dishwasher will not fill with water | nancyrice | Dishwasher Repair | 4 | 07-09-2009 05:43 PM |
