Discuss
Dishwasher won't run
 in
Dishwasher Repair
Our dishwasher will not run in any of the wash cycles, sometimes the Delay Hours light would stay on or
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher won't run
  #1 (permalink)
Old 09-02-2009, 10:10 AM
Junior Member
jotisch is on a distinguished road
Default Dishwasher won't run
Model Number: GU940SCGB2   Brand: Whirlpool   Age: 5 - 10 years
Our dishwasher will not run in any of the wash cycles, sometimes the Delay Hours light would stay on or blink and you could get it to run in Normal Cycle if you played with the door switch long enough, so we finally replaced with the "Door Switch Repair Kit" that didn't change anything. So we recently replaced the "Electronic Control Assembly" and still it won't wash, but now the "Rinse Only" "China" and "Cancel/Drain" buttons are all flashing.
We are thinking the next step might be the Thermal Fuse, but since we have lights on the front didn't know if that would be necessary. At this rate if we keep trying these things we could have paid for a new one!! Please help, any suggestions as to what to do next?
Jo
Ads By Google
Related Models
Whirlpool GU940SCGB2
Whirlpool GU940SCGB3
Whirlpool GU940SCGQ0
Whirlpool GU940SCGQ1
Whirlpool GU940SCGQ2
Whirlpool GU940SCGQ3
Whirlpool GU940SCGT3
Whirlpool GU940SCGZ0
Whirlpool GU940SCGZ1
Whirlpool GU940SCGZ2
Whirlpool GU940SCGZ3
Whirlpool GU960SCGB0
Whirlpool GU960SCGQ0
Whirlpool GU980QPDB0
Whirlpool GU980QPDQ0
Whirlpool GU980QPDZ0
Whirlpool GU980SCGB0
Whirlpool GU980SCGB1
Whirlpool GU980SCGB2
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
  #2 (permalink)
Old 09-02-2009, 05:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jo,
Sounds like the problem is a bad key pad and it was probably wrong from the beginning. The part number for the control panel are different for different colors as you can see from the parts diagram: Replacement parts for WHIRLPOOL GU940SCGB2 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-28-2009, 07:50 PM
Junior Member
Default Dishwasher is up and running!!
Gene,
Thanks so much for the advice, that was the problem. We are up and running now. Thanks again.
Jo
  #4 (permalink)
Old 09-29-2009, 06:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad to know you are back in business.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
