Discuss
Tub fills with water
 in
Dishwasher Repair
I have a Bosch dishwasher that is eight years old. A few months ago I found clear water in the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Tub fills with water
  #1 (permalink)
Old 01-21-2008, 12:18 PM
JoelK JoelK is offline
Junior Member
JoelK is on a distinguished road
Default Tub fills with water
Model Number: SHU9920UC   Brand: Bosch   Age: 5 - 10 years
I have a Bosch dishwasher that is eight years old. A few months ago I found clear water in the tub following a wash done the previous evening. I drained the tub by resetting the cycle as instructed in the user manual, but the tub gradually filled up with water again after several hours. This now happens after every few washes. When I turn off power to the dishwasher, the tub still fills with water. There seems to be a slow leak in the water intake valve, but I'm not sure why this happens only intermittently, that is every few washes. Do I need to replace the water valve? If so, what's the difference between the Bosch Water valve (part No. AP2802210) and Water valve assembly (part No. AP3783031)? Thanks for you help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 07:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The water inlet valve has to be replaced because it's stuck.
I'm not able to provide the right part number due to the model number you posted is incorrect. Verify and repost it, please.
The water inlet valve with the part number AP2802210 has a pressure switch attached. The other one does not have it.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-22-2008, 11:33 AM
Junior Member
Default Model Number
The ID tag for the model number is missing from the door, but my original invoice indicates that the model is SHU9902UC. The manual that came with the dishwasher shows the model as SHV4300. The part numbers for the water intake valves are the same for both models. The part no. for the water valve assembly is AP3783031 and for the water inlet system is AP2802392. Which do I need? Thanks for your quick response Gene.
  #4 (permalink)
Old 01-23-2008, 02:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In such situation the best thing is to remove the old part and match it up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fills and stops metten2@verizon.net Washer Repair 9 01-08-2008 02:57 PM
Ice Maker fills water but...that's it. amati5 Refrigerator & Freezer Repair 2 12-19-2007 04:56 PM
water fills and stops intermittently worldtravelert Washer Repair 0 12-08-2007 10:50 AM
washer fills with water then run program cancels Doug Quinn Washer Repair 0 11-03-2007 09:39 PM
Water Is Draining As It Fills jbgreer Washer Repair 2 09-03-2007 11:52 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
