Discuss
Frigidaire won't drain fully!
 in
Dishwasher Repair
Help! My dishwasher won't drain fully. I disconnected the wash motor and the drain motor and made sure no debris
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Frigidaire won't drain fully!
  #1 (permalink)
Old 04-11-2012, 04:43 PM
Junior Member
drainwoes is on a distinguished road
Exclamation Frigidaire won't drain fully!
Model Number: FDB750RCB0   Brand: Frigidaire   Age: 1 - 5 years
Help! My dishwasher won't drain fully. I disconnected the wash motor and the drain motor and made sure no debris was impeding their movement. I made sure nothing was blocking the drain hose. I did a thorough cleaning of the internal mesh filter. I have been reading some forums and it seems that a solenoid might be part of the problem, but I can't figure out what this is, where it 'lives' on the dishwasher, and/or whether it is part of the drain pump. I am about to go out an buy a new drain pump but thought I'd get some advice first! Thank you so much in advance.
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 04-11-2012, 05:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you check the flapper valve (black piece) in the drain pump outlet (on the left side)?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-11-2012, 05:55 PM
Junior Member
Default Frigidaire dishwasher won't fully drain
Hi Gene. Thank you for this response! I am not sure what you mean by "check" the flapper valve. I have noticed that there is a flapper valve and have cleaned it off and poked it with my finger a bit. Is there more I can do to see if it is doing its job? For example, should it be loose (easy to poke open) or stiff (hard to poke open)? Mine is quite loose...
  #4 (permalink)
Old 04-12-2012, 03:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The purpose of this valve is to prevent a dirty water from coming back into the dishwasher, so it should open one way only under the pressure created by the pump. If it does not open all the way or it's not closed while the pump is off, the pump has to be replaced.
__________________
  #5 (permalink)
Old 04-17-2012, 10:21 AM
Junior Member
Hi again Gene. I installed a new drain pump and the machine works better than it has in years. I think this was a smaller problem that got bigger over time, because with the new pump the inside of the machine is super clean at the end of a wash, whereas before it was always a bit dirty/grimy in there and then lately of course I had a few inches of water left over at then end of a wash. Anyway, a HUGE thank you to you for your guidance!!! I am thrilled with this helpful forum.
  #6 (permalink)
Old 04-17-2012, 02:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad it's up and running.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher won't fully drain gweidenh Dishwasher Repair 0 10-03-2011 07:58 PM
GE Dishwasher won't fully drain GoldenRose Dishwasher Repair 0 09-16-2011 01:47 PM
Bosch DW doesn't drain fully flashypants Dishwasher Repair 0 01-03-2011 10:43 AM
Washer does not fully drain JMJNet Washer Repair 1 07-06-2010 01:06 PM
Dishwasher Does Not Fully Drain braun647 Dishwasher Repair 0 03-28-2008 08:09 AM
