Discuss
flooded
 in
Dishwasher Repair
When the water valve opens it fills the water inlet assembly and water begins to flow out of the breather
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » flooded
  #1 (permalink)
Old 01-20-2008, 10:22 PM
zekebc zekebc is offline
Junior Member
zekebc is on a distinguished road
Default flooded
Model Number: shu3032uc   Brand: Bosch   Age: 5 - 10 years
When the water valve opens it fills the water inlet assembly and water begins to flow out of the breather hole at the top of the assembly. The water level and float switch assembly are not filled. It just seems the inlet hose can put in more water than the assembly can let out. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 06:47 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
if you turn the d/w on and allow the d/w to fill, while filling, if you just turn d/w to off, does it still continue to fill ?
__________________
regards
jim
  #3 (permalink)
Old 01-21-2008, 02:18 PM
Junior Member
Default
If you turn the d/w off the water stops, but as soon as you start fo fill within 5 sec water starts to flow out the breather hole on the water inlet assembly. This continues untill the tub is full and then the fill stops at the right level. The cycle continues as normal untill water is called for again, then the same routine all over.
  #4 (permalink)
Old 01-22-2008, 07:45 AM
Senior Expert
APP Volunteer
Default
change the valve...
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
