Discuss
Bosch - who can guess the problem
 in
Dishwasher Repair
Our dishwasher has had some of the same problems as others - mainly the countdown sticking at "1", sometimes
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch - who can guess the problem
  #1 (permalink)
Old 01-20-2008, 07:02 PM
slonez slonez is offline
Junior Member
slonez is on a distinguished road
Default Bosch - who can guess the problem
Model Number: SHUC5315UC   Brand: Bosch   Age: 5 - 10 years
Our dishwasher has had some of the same problems as others - mainly the countdown sticking at "1", sometimes water remaining in the bottom, and sometimes the cycles taking for ever. I've checked the control panel and there are no burnt spots, and from time to time, the dang thing actually works like it's supposed to. With so many possibilities, does anyone have an idea or where/what to check? I've read about the control panel, but hate to order and replace this part and it not work (correctly read as wife would have my head). Any help is greatly appreciated!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-20-2008, 07:13 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
really check the control module... very rare that you have a heater problem .. do you have an amp meter ? you'll need it in order to diagnose problem better... a volt meter would also be helpful
__________________
regards
jim
  #3 (permalink)
Old 01-20-2008, 07:47 PM
Junior Member
Default
Jim, thank you for the reply. I have a volt meter, and can find an amp meter
  #4 (permalink)
Old 01-20-2008, 08:22 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
i have come across this problem many times .if it fills .washes +cancells to a normal drain,it will be control module
__________________
  #5 (permalink)
Old 01-20-2008, 09:20 PM
Junior Member
Default
I've just run another cycle with a thermometer in the silverware holder. It doesn't appear that the temp has made it over about 95. Does this still hold true? D
  #6 (permalink)
Old 01-21-2008, 06:03 AM
Senior Expert
APP Volunteer
Default
actual water temp should be between 120- 140 F. turn hot water on at sink /you shoud see steam pretty quickly .and steam when you open d/w door ,if not water is not hot enough. i still feel control module may be problem
__________________
  #7 (permalink)
Old 01-21-2008, 06:41 AM
Senior Expert
APP Volunteer
Default
if you have a thermometer that you could leave in the d/w , (w/o running hot water in sink , as it is easier to see a temp change ) Must check 10 minutes after soap dispenser opens. check the difference between water temp at the pre-rinse and then 12 minutes after the dispenser opens .. if you have a substantial rise in temp, module and heater are ok..
__________________
regards
jim
  #8 (permalink)
Old 01-21-2008, 09:12 AM
Junior Member
Default
O.K. if you don't mind, and I hope it's not a stupid question, but how does one know when the dispenser opens to start the timer for 12 minutes?
  #9 (permalink)
Old 01-22-2008, 07:40 AM
Senior Expert
APP Volunteer
Default
i close the dispenser and if you pop it open yourself you'll recognize that same sound after a little while... this means you'll need to stay in the kitchen after you start d/w... but once you hear the dispenser door pop open, you should wait a while and you can usually see a 1-2 rise in temp per minute ( 90 sec depending on incoming voltage ) .. mind you do not put detergent in d/w for this test ...
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxis dryer problem Chipper Dryer Repair 2 04-01-2008 06:43 PM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 10:05 AM
Bosch memyer Dishwasher Repair 2 12-19-2007 06:31 AM
Bosch dishwasher Elise Dishwasher Repair 9 11-13-2007 04:46 PM
Bosch problem. Burt Isenstein Dishwasher Repair 0 08-26-2007 01:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
