Discuss
Whirlpool Dishwasher not circulating
 in
Dishwasher Repair
Hi, My dishwasher is not circulating water though out the machine. The water fills correctly and then the circulating pump
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Dishwasher not circulating
  #1 (permalink)
Old 04-07-2012, 09:58 AM
Junior Member
corkboy12 is on a distinguished road
Unhappy Whirlpool Dishwasher not circulating
Model Number: ADG 7440   Brand: Whirlpool   Age: 5 - 10 years
My dishwasher is not circulating water though out the machine. The water fills correctly and then the circulating pump comes on. However there does not seems to be enough pressure. I stripped down the pump, removed the heater and checked the pump by applying 220v directly and it works fine with plenty of power. I put everything back together and again all the processes seem to be working, but no pressure to the sprinklers.
I checked and during pumping there is the full 220 volts to it. (However I would say there is a noise from the pump). Any help would be appreciated. Thanks.
Colm.
Ads By Google
Related Models
Maytag ADG107 Dryer - Gas
Admiral ADG20K2A Dryer - Gas
Admiral ADG20K2H Dryer - Gas
Admiral ADG20K2W Dryer - Gas
Admiral ADG20K3 Dryer - Gas
Admiral ADG20K3A Dryer - Gas
Admiral ADG20K3H Dryer - Gas
Admiral ADG20K3V Dryer - Gas
Admiral ADG20K3W Dryer - Gas
Admiral ADG20K4 Dryer - Gas
Admiral ADG20K4A Dryer - Gas
Admiral ADG20K4H Dryer - Gas
Admiral ADG20K4W Dryer - Gas
Admiral ADG20L1A Dryer - Gas
Admiral ADG20L1H Dryer - Gas
Admiral ADG20L1W Dryer - Gas
Admiral ADG20L2A Dryer - Gas
Admiral ADG20L2H Dryer - Gas
Admiral ADG20L2W Dryer - Gas
Admiral ADG20L4 Dryer - Gas
Admiral ADG20L4A Dryer - Gas
Admiral ADG20L4H Dryer - Gas
Admiral ADG20L4W Dryer - Gas
Admiral ADG20M3V Dryer - Gas
Admiral ADG20N3V Dryer - Gas
Maytag ADG308 Dryer - Gas
Maytag ADG309 Dryer - Gas
Maytag ADG408 Dryer - Gas
Maytag ADG409 Dryer - Gas
Maytag ADG608 Dryer - Gas
Admiral ADG7000AWW Dryer - Gas
Admiral ADG7005AWW Dryer - Gas
Maytag ADG808 Dryer - Gas
Admiral ADG9000AWW Dryer - Gas
Amana ADGS902E Range - S/c S/i Ddraft Gas
Amana ADGS902SS Range - S/c S/i Ddraft Gas
Amana ADGS902WW Range - S/c S/i Ddraft Gas
General Electric ADH15D3Z1 Room air conditioner
General Electric ADH18D1G1 Room air conditioner
General Electric ADH18D1G2 Room air conditioner
General Electric ADH18D1G3 Room air conditioner
General Electric ADH18D3E1 Room air conditioner
General Electric ADH23D1X1 Room air conditioner
General Electric ADH23D3B1 Room air conditioner
Whirlpool ADJ06020
Whirlpool ADJ07220
Whirlpool ADJ07221
Whirlpool ADJ07520
Whirlpool ADJ07521
Whirlpool ADJ07522
Whirlpool ADJ10220
Whirlpool ADJ17840
Whirlpool ADJ17841
Whirlpool ADJP0521
Whirlpool ADJP0522
Whirlpool ADJP0523
Whirlpool ADJP5220
Whirlpool ADJP5221
Whirlpool ADL18091
Whirlpool ADL25091
Amana ADM-1B Range - S/c S/i Ddraft Gas
Whirlpool ADM08090
Amana ADM1B Walloven - Std Ele
Amana ADM1C Walloven - Std Ele
Amana ADMIC Range - S/c S/i Ddraft Gas
General Electric ADN18DAG2 Room air conditioner
General Electric ADN19DSG1 Room air conditioner
General Electric ADN24DBX1 Room air conditioner
General Electric ADN24DBX2 Room air conditioner
General Electric ADN24DSB1 Room air conditioner
General Electric ADP18DAG1 Room air conditioner
General Electric ADP23DAH1 Room air conditioner
General Electric ADR18DAG2 Room air conditioner
General Electric ADR18DAG3 Room air conditioner
General Electric ADR19DCG1 Room air conditioner
General Electric ADR19DDG1 Room air conditioner
General Electric ADR19DSG1 Room air conditioner
General Electric ADR24DAX1 Room air conditioner
General Electric ADR24DAX2 Room air conditioner
General Electric ADR24DAX3 Room air conditioner
General Electric ADR24DCX1 Room air conditioner
General Electric ADR24DSB1 Room air conditioner
Amana ADU3000CB Dishwasher - Undercounter
Amana ADU3000DB Dishwasher - Undercounter
Amana ADU3000DWW Dishwasher - Undercounter
Amana ADU5000C Dishwasher - Undercounter
Amana ADU5000CB Dishwasher - Undercounter
Amana ADU5000CWW Dishwasher - Undercounter
Amana ADU5000DB Dishwasher - Undercounter
Amana ADU5000DWW Dishwasher - Undercounter
Amana ADU6000C Dishwasher - Undercounter
Amana ADU6000CB Dishwasher - Undercounter
Amana ADU6000CWW Dishwasher - Undercounter
Amana ADU6000DB Dishwasher - Undercounter
Amana ADU6000DWW Dishwasher - Undercounter
Amana ADU6500CBB Dishwasher - Undercounter
Amana ADU6500CWW Dishwasher - Undercounter
Amana ADU7000C Dishwasher - Undercounter
Amana ADU7000CBB Dishwasher - Undercounter
Amana ADU7000CLL Dishwasher - Undercounter
Amana ADU7000CWW Dishwasher - Undercounter
  #2 (permalink)
Old 04-09-2012, 08:50 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find any tech info on this unit.
But you said the pump gets 220 volts so I am assuming this is a non-USA unit and I do not have access to any info.
A common problem is the unit not filling with enough water.
Most units fill to just under the heating element.
This can be checked by adding a couple quarts of water after each fill during a cycle.
Just be careful to not overfill it.
If it now washes OK then check the fill valve.
Often if the fill is low you will also hear a growling sound because the pump will cavitate (suck in air).
The most common cause is a dirty screen filter on the input side of the fill valve. Remove the valve from the unit and clean/check the filter.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it still does not fill correctly I would replace the fill valve.
PS: Be sure to shut off the power and the water supply to the unit. Have paper towels etc. handy to wipe up any spilled water. Get a small pan/bowl etc. that will fit under the valve then loosen the input water line let it drip into the container emptying it as necessary. This will minimize the amount of water spilled.
__________________
  #3 (permalink)
Old 04-11-2012, 10:36 AM
Junior Member
Default
Ok, on this Dishwasher there does not seem to be any filter on any part of the circulation system. The water is sucked in from the side of the basin which is full of water. and should pass by the motor impeller and shoot into the sprays ?. The motor is still making a growling noise but feels like it is running and as mentioned it runs perfectly on the test bench, but not pumping in the machine. I assume I am correct in my assumption that the water fills into the basin, there is a pressure switch on the side of the basin which then indicates to the motor to start to run and circulate the water. The only other pump I can see is on the water extraction outlet. It does sound lie a motor problem. Any other things I could check ?
Thanks, Colm.
  #4 (permalink)
Old 04-12-2012, 03:43 AM
Senior Expert
APP Volunteer
Default
Sorry but I cannot be very helpful on this unit as I have no info on it.
I have never see a unit that feeds the pump from the side or one that does not have a filter somewhere is the water flow path.
I was able to find some parts lists unfortunately I could not find a parts breakdown. The list did have a part called a sieve cover so there is probably a filter under the spray arms.
It could be that the pump works with no load but will not pump when it has a load on it. Could be it is toast.
When you had it out did you check that the impeller was solidly connected to the motors armature/shaft? Could be it is slipping on the shaft.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher not circulating water Joshpalmer Dishwasher Repair 1 03-09-2011 04:31 PM
KitchenAid Dishwasher isn't circulating the water! Evie21 Dishwasher Repair 0 02-27-2011 03:26 PM
Bosch SHE44C Dishwasher never stops circulating Fixtime Dishwasher Repair 8 01-06-2010 08:09 PM
bosch dishwasher is not cleaning - water is not hot and not circulating justkoz Dishwasher Repair 2 01-02-2009 02:19 PM
Water not circulating in dishwasher maryannsienk Dishwasher Repair 11 11-10-2008 08:05 PM
