| » Dishwasher drain issue |
Model Number: FD84050LHB1 Brand: Frigidaire Age: 1 - 5 years
My dishwasher is washing the dishes, but after cycle is complete the pan on bottom is still full of water. It must be pumping some water, because it doesn't leak all over the floor. I have checked to see if there is anything blocking the drain, and didn't find anything. Anyone?
Hi.
Open the air gap, check for clogs, remove the drain hose from air gap and see if there any debris. If you can't find any restrictions in the drain remove the toe panel and with control set for drain see if the drain pump is running. Using the multimeter check for 120v at the pump contacts. If you are getting 120v and the pump is not working or it's working, but not draining properly - replace the pump. The drain pump Part number: AP4019644 Here are the breakdown diagrams and Replacement parts for Frigidaire FDB4050LHB1 DISHWASHER | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag D/W: - drain after wash issue but cancel/drain works fine after.... | diesan2011 | Dishwasher Repair | 0 | 08-10-2011 11:39 AM |
| dishwasher drain issue | fungez | Dishwasher Repair | 3 | 07-20-2010 07:50 AM |
| Frigidaire dishwasher Drain pump issue? | angusjp | Dishwasher Repair | 0 | 05-05-2010 03:03 PM |
| GE Triton Dishwasher, Another Drain Issue | mdax1101 | Dishwasher Repair | 0 | 12-09-2009 10:36 PM |
| Another won't drain issue | yabadabadoo1026 | Washer Repair | 3 | 01-28-2008 08:12 PM |
