| » top rack arms not turning |
Model Number: KUDP01DLBSO Brand: Kitchen Aid Age: 5 - 10 years
I am getting no water to the two top arms on my dishwasher. I have removed the accumulator assembly and cleaned out anything that was in there. Still not getting any water on top arms. Is there something else I need to check or clean or do I possibly have a bad pump? Bottom arm seem to be turning and spraying but I cannot tell how much pressure there is coming out.
Bill Ads By Google Related Models |
Hi.
Inside the pump housing there is the Protector (number #8 at the diagram#9)located at approximately 7 o'clock.Check if it's plugged. Check the wash arm jets and feed tube at the back for any blockage. Check the water level. Add few cups of water during the wash. If the problem is with the level of water, check the screen inside the water valve. Here are the breakdown diagrams and http://www.appliancepartspros.com/pa...del_id=5141714 Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks Simon. I found the problem. Removed the protector over the chopper and it was in pieces. The blade had come off and the screen was completely blocked. I replaced the chopper and seems to work fine. Thanks for your help.
Hi.
I'm glad you where able to fix it. Good team. Thank you. Simon.
__________________
| Display Modes | |
| installing cup rack clips on upper dishwasher rack | acnp2b1 | Dishwasher Repair | 0 | 04-08-2011 04:26 PM |
| after removing the bottom wash rack&arms how do you remove the small center bolt | juskim | Dishwasher Repair | 1 | 02-02-2011 03:43 AM |
| Whirlpool- Arms turning very slowly | thebarndoor | Dishwasher Repair | 0 | 09-11-2009 08:33 AM |
| GE Quiet Power III spray arms not turning | alw | Dishwasher Repair | 4 | 11-08-2008 05:05 AM |
| spray arms not turning | jon6180 | Dishwasher Repair | 1 | 01-17-2008 03:50 PM |
