| » Help!! My dishwasher won't drain |
Model Number: gu1500xtkbo Brand: Whirlpool Age: 5 - 10 years
Help, my dishwasher won't drain. I have no idea how to get it apart to clean the drain or check anything that might be suggested
Can you hear the drain pump running when it should be draining? If it sounds like the pump is running the first thing I would do is remove the drain hose from under the sink, maybe it connects to a food disposal and just look into the hose and connection for anything blocking the flow. Also check the drain hose for kinks. If the drain hose has a splice or other connection anyway in the hose that is another spot they like to plug up. If you can't hear the drain pump running I would check it with a multimeter for continuity. If it has no continuity then you need to replace the drain pump.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| Fridigaire dishwasher no power to the dishwasher and water will not drain out | jarhead1984 | Dishwasher Repair | 0 | 02-27-2012 07:43 AM |
| Dishwasher won't drain, push cancel/drain button will clicking then hum, no draining | bluelakes77 | Dishwasher Repair | 0 | 11-10-2011 09:17 PM |
| Dishwasher drain motor not spinning and won't drain | bwp | Dishwasher Repair | 1 | 01-02-2011 03:39 PM |
| dishwasher will not drain (drain pump is new) | jkda1975 | Dishwasher Repair | 1 | 04-06-2010 01:56 PM |
| Dishwasher won't drain | Ikekey | Dishwasher Repair | 0 | 06-12-2009 08:20 PM |
