Discuss
Admiral does not Spin, Rinse or drain
 in
Dishwasher Repair
Hello, My admiral washer machine stopped at mid cycle and does not spin, drain or continue. MAIN knob will not
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Admiral does not Spin, Rinse or drain
  #1 (permalink)
Old 03-30-2012, 08:10 AM
Junior Member
hime is on a distinguished road
Default Admiral does not Spin, Rinse or drain
Model Number: LNC6764A71   Brand: Admiral   Age: 5 - 10 years
Hello,
My admiral washer machine stopped at mid cycle and does not spin, drain or continue. MAIN knob will not ADVANCE.
I emptied, and I checked the following:
1) Lid switch and works fine. It clicks,I took it out and check continuity and it is good.
2)The drain pump is good. I took it off and it is clean an rotates fine
3) Belt is fine.
4) All pulleys rotate freely manually from underneath, after taking belt off.
5) ordered a new timer and belt and installed them. Same problem: Main Knob will not advance. I can hear a low sound that you always hear when it would be getting ready to advance to next step on cycle but it never advances.
6) Water supply is fine and fills up ok.
7) When I spin main pulley manually from underneath without a belt, the agitator moves fine.
Machine will not spin or rinse or drain even if i try to move main knob manually to do these.
I need advise what to do next.
Thank you very much
Ads By Google
Related Models
Admiral LNC6764A71 Washer - Top Loading
Admiral LNC6766A00 Washer - Top Loading
Admiral LNC6766A01 Washer - Top Loading
Admiral LNC6766A71 Washer - Top Loading
Admiral LNC6766A77 Washer - Top Loading
Admiral LNC6766B71 Washer - Top Loading
Admiral LNC7760A00 Dryer - Ele
Admiral LNC7760A71 Dryer - Ele
Admiral LNC7764A00 Dryer - Ele
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer won't spin, drain, or rinse crystal adkins Washer Repair 3 10-02-2011 05:33 AM
No spin, drain or rinse in washer budkoc Washer Repair 1 12-06-2010 06:30 AM
Admiral Washer makes noises but will drain/spin Helpindiana Washer Repair 0 06-14-2010 02:55 PM
HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works cosmo99 Washer Repair 1 01-27-2010 11:33 AM
Admiral Won't Agitate,spin,drain ronjon Washer Repair 1 08-12-2009 06:16 AM
