| » clean light keeps flashing |
Model Number: GU2400XTP53 Brand: Whirlpool Age: 1 - 5 years
the "clean" light has started flashing and we can't reset it. Pressing the run button doesn't start the washer. Pressing the cancel button gives two bars in the display panel.
Washer won't start. New control panel needed? Is this a continuing problem with this model? Ads By Google Related Models |
The Clean LED blinking 7 times in repetitive fashion means the control detected no temperature increase in heated intervals.
Try to clear the control by pressing the following keys, in order, in less than 6 seconds, while in standby: Heated Dry, Normal, Heated Dry, Normal. If the control will stop running again, post it and we will proceed with further troubleshooting. The model number you posted is incorrect. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I reset using your procedure ans so far it's working.
What would be the possible cause of the unit going into the flashing mode? We had a repairman out here and he told us it was the control panel. The correct model # GU2400XTPS3 |
Quote:
Otherwise there is something wrong wit the parts involved in the water heating process. They are" the heater, the high limit thermostat and the control board. Here are the breakdown diagrams and Replacement parts for Whirlpool GU2400XTPS3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Whirlpool Quiet Partner ii clean light flashing - have reset, still flashing | emilyoh | Dishwasher Repair | 22 | 01-30-2013 07:27 AM |
| clean light flashing | alashard | Dishwasher Repair | 1 | 12-24-2011 07:12 AM |
| clean light flashing | sro | Dishwasher Repair | 1 | 11-11-2011 09:46 PM |
| Clean Light flashing | Jasper22 | Dishwasher Repair | 1 | 05-20-2010 09:57 PM |
| Clean light flashing, will not run | bclout | Dishwasher Repair | 0 | 02-21-2010 03:11 PM |
