| » burnt wires on bosch dishwasher |
Hi, Pete.
You definitely has a good one. Check couple of things. May be the reversed polarity at the junction box or copper to aluminum connection. Make sure that the wire nut is correct size and tightened good. There is one more thing: check the power cord plug for brakes and/or discoloration. You may need to replace wall receptacle and power cord. Thank you. Post the results.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Quote:
Model SHX56C/23 BOUGHT NEW 1/07 15 MONTHS LATER WOULD NOT START.4/08, REPAIRMAN CAME OUT AND FOUND BURNT WIRES IN J.B., REPAIRED DAMAGED WIRES. LESS THEN A YEAR LATER, IT WOULDN'T. I FOUND THE SAME PROBLEM- WIRE BURNT IT J.B. I REPAIRED THE WIRES MYSELF. THEN CALLED A REPAIRMAN THAT WORKS ON BOSCH APPLIANCES AND HE CHECKED THINGS OUT AND CAME UP WITH THE SAME THING THAT I THOUGHT.FEED WIRES GOING J.B WHERE 3C/16. WIRES WHERE TO OSMALL. IREPLACED THE WIRES WITH A 3C12. SHOULD THIS CORRECT THE BURNING WIRE PROBLEM? A FRIEND OF MY TOLD ME HE HEARD OF ANOTHER BOSCH WITH THE SAME PROBLEM THAT I HAD. EXCEPT HIS WIRE WAS A 3C14. THERE IS A RECALL BUT NOT MY MODEL ON FIRES IN BOSCH DISHWASHER Read more: BOSCH Dishwasher burnt wires in J.B. http://forum.appliancepartspros.com |
| Display Modes | |
| Dishwasher Thermostat Wires | broxys123 | Dishwasher Repair | 1 | 12-10-2011 11:17 AM |
| Bosch Oven Relay Burnt | belmojo | Oven Repair (including Ranges and Cooktops) | 0 | 12-01-2010 07:00 PM |
| Burnt Wires Connecting Heater Coil | williamsvd | Dryer Repair | 6 | 08-02-2010 12:23 PM |
| Burnt wires | blur | Dryer Repair | 1 | 11-07-2009 11:01 AM |
| BOSCH Dishwasher burnt wires in J.B. | tam62@att.net | Dishwasher Repair | 0 | 04-09-2009 07:33 PM |
