Discuss
Kenmore DW won't drain
 in
Dishwasher Repair
I don't know where to look for a model number. I see several on the manual: 15791, 15795, 15798, 16791,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore DW won't drain
  #1 (permalink)
Old 03-23-2012, 10:26 PM
Junior Member
ionized is on a distinguished road
Default Kenmore DW won't drain
Model Number: 15791   Brand: Kenmore   Age: More than 10 years
I don't know where to look for a model number. I see several on the manual: 15791, 15795, 15798, 16791, 16795, 16798.
It seems to run a whole cycle, but is full of water at the end.
Ads By Google
Related Models
Frigidaire 157931A
Frigidaire 157932A
Frigidaire 157933A
Amana 1580.0 Mwave - Family Size (60 Hz)
Amana 1580.000 Mwave - Family Size (60 Hz)
Amana 1585.000 Mwave - Family Size (60 Hz)
General Electric 15891 1
Amana 1590.000 Mwave - Family Size (60 Hz)
Amana 1590.001 Mwave - Family Size (60 Hz)
Amana 15A Freezer - Vertical
Amana 15B Freezer - Vertical
Amana 15C Freezer - Vertical
Magic Chef 15G-1-94 Range - F/s Std Ele
Magic Chef 15GA-1 Range - F/s Std Ele
Magic Chef 15GA-1-94 Range - F/s Std Ele
Magic Chef 15GA-1-GG Range - F/s Std Ele
Magic Chef 15GA-10 Range - F/s Std Ele
Magic Chef 15GK-1
Magic Chef 15GK-1-GG Range - F/s Std Ele
Magic Chef 15GK-10 Range - F/s Std Ele
Magic Chef 15GN-1 Range - F/s Std Ele
Magic Chef 15GN-1-94 Range - F/s Std Ele
Magic Chef 15GN-1-GG Range - F/s Std Ele
Magic Chef 15GN-10 Range - F/s Std Ele
Magic Chef 15GY-1 Range - F/s Std Ele
Magic Chef 15GY-1-GG Range - F/s Std Ele
Magic Chef 15GY-10 Range - F/s Std Ele
Magic Chef 15H-10-94
Magic Chef 15H-10-GG
Magic Chef 15HA-10 Range - F/s Std Ele
Magic Chef 15HA-10-94 Range - F/s Std Ele
Magic Chef 15HA-10-GG Range - F/s Std Ele
Magic Chef 15HK-10
Magic Chef 15HK-10-94
Magic Chef 15HN-10 Range - F/s Std Ele
Magic Chef 15HN-10-94 Range - F/s Std Ele
Magic Chef 15HN-10-GG Range - F/s Std Ele
Magic Chef 15HY-10 Range - F/s Std Ele
Magic Chef 15HY-10-94
Amana 16 Freezer - Vertical
Amana 16-3SPMK Room Air Conditioner
Amana 1607.000 Mwave - Family Size (60 Hz)
Amana 1607.001 Mwave - Family Size (60 Hz)
Amana 1608.000 Mwave - Family Size (60 Hz)
Amana 1608.001 Mwave - Family Size (60 Hz)
Amana 1608.002 Mwave - Family Size (60 Hz)
Amana 1608.004 Mwave - Family Size (60 Hz)
Amana 1609.000 Mwave - Family Size (60 Hz)
Amana 1609.001 Mwave - Family Size (60 Hz)
Amana 1618.000 Mwave - Family Size (60 Hz)
Amana 1618.001 Mwave - Family Size (60 Hz)
Amana 1618.002 Mwave - Family Size (60 Hz)
Amana 1618.004 Mwave - Family Size (60 Hz)
Whirlpool 1633W0A
Whirlpool 1633W1A
Whirlpool 1633W2A
Whirlpool 1633^0A
Whirlpool 1633^1A
Whirlpool 1633^2A
Amana 1635.000 Mwave - Family Size (60 Hz)
Amana 1635.001 Mwave - Family Size (60 Hz)
Amana 1636.000 Mwave - Family Size (60 Hz)
Amana 1636.001 Mwave - Family Size (60 Hz)
Amana 1639.000 Mwave - Family Size (60 Hz)
Amana 1639.001 Mwave - Family Size (60 Hz)
Amana 1639.002 Mwave - Family Size (60 Hz)
Amana 1639.004 Mwave - Family Size (60 Hz)
Whirlpool 1643W0A
Whirlpool 1643W1A
Whirlpool 1643W2A
Whirlpool 1643^0A
Whirlpool 1643^1A
Whirlpool 1643^2A
Whirlpool 1653W0A
Whirlpool 1653W1A
Whirlpool 1653W2A
Whirlpool 1653^0A
Whirlpool 1653^1A
Whirlpool 1653^2A
Hoover 168691 Electrolux/refrigerator
Magic Chef 16RA-3B Rv Range - Gas
Magic Chef 16RA-3B-49 Rv Range - Gas
Magic Chef 16RA-3BK Rv Range - Gas
Magic Chef 16RA-3BKZ Rv Range - Gas
Magic Chef 16RA-3BT Rv Range - Gas
Magic Chef 16RA-3BT49 Rv Range - Gas
Magic Chef 16RA-3BTZ Rv Range - Gas
Magic Chef 16RA-3BZ Rv Range - Gas
Magic Chef 16RA-4 Rv Range - Gas
Magic Chef 16RA-4K Rv Range - Gas
Magic Chef 16RA-4KZ Rv Range - Gas
Magic Chef 16RA-4T Rv Range - Gas
Magic Chef 16RA-4TZ Rv Range - Gas
Magic Chef 16RA-4Z Rv Range - Gas
Magic Chef 16RB-3B Rv Range - Gas
Magic Chef 16RB-3BK
Magic Chef 16RB-3BKZ
Magic Chef 16RB-3BT Rv Range - Gas
Magic Chef 16RB-3BTZ Rv Range - Gas
Magic Chef 16RB-3BZ Rv Range - Gas
Magic Chef 16RB-4 Rv Range - Gas
Magic Chef 16RB-4K
Magic Chef 16RB-4KZ Rv Range - Gas
Magic Chef 16RB-4T
Magic Chef 16RB-4TZ Rv Range - Gas
Magic Chef 16RB-4Z Rv Range - Gas
Magic Chef 16RS-4 Rv Range - Gas
Magic Chef 16RS-4K Rv Range - Gas
Magic Chef 16RS-4KZ
Magic Chef 16RS-4T Rv Range - Gas
Magic Chef 16RS-4TZ
Magic Chef 16RS-4Z Rv Range - Gas
Magic Chef 16RW-3B Rv Range - Gas
Magic Chef 16RW-3B-49 Rv Range - Gas
Magic Chef 16RW-3BK Rv Range - Gas
Magic Chef 16RW-3BKZ Rv Range - Gas
Magic Chef 16RW-3BT Rv Range - Gas
Magic Chef 16RW-3BT49 Rv Range - Gas
Magic Chef 16RW-3BTZ Rv Range - Gas
Magic Chef 16RW-4 Rv Range - Gas
  #2 (permalink)
Old 03-24-2012, 06:40 AM
Junior Member
Default
I found the tag. It looks like a model number 665.15798.790.
Where should I start?
  #3 (permalink)
Old 03-26-2012, 11:36 AM
Junior Member
Default
I put some food coloring into the water in the first wash cycle to see if it drains between wash and rinse. It stayed blue at the end.
  #4 (permalink)
Old 03-26-2012, 03:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the bottom panel. Disconnect the drain hose from the check valve (#15 on the attached picture). Be prepared to catch the water remaining inside the dishwasher. Unscrew the check valve and make sure it is clean inside.
In case if you would not be able to clean it or if some parts of it are missing, replace the check valve.
- The check valve Part number: AP2910020
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #5 (permalink)
Old 03-27-2012, 11:06 AM
Junior Member
Default
Thanks, I will look into the check valve. It will likely be the weekend before I have time.
  #6 (permalink)
Old 03-27-2012, 03:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 03-27-2012, 09:08 PM
Junior Member
Default
I took out the check valve and it seems to be clear as does the drain. Water seemed to run freely from the tub. I suppose, however, there could be a clog above the check valve connection that allowed water do seep through slowly and then pour out when the valve was removed. I can check that tomorrow. If that is not it, what is next, check the pump? If so, how do I do that? I might be able to cobble together some scrap tubing that I can adapt to the check valve and drain hose.
  #8 (permalink)
Old 03-28-2012, 04:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Do you have an air gap on top of the sink?
__________________
  #9 (permalink)
Old 03-28-2012, 04:06 PM
Junior Member
Default
No air gap. I have been holding back. This DW is hooked up in an unconventional and, perhaps, not code compliant way. I knew for a long time that it is not hooked to the plumbing on the double sink next to it. It is a raised house with an open crawl space. There is insulation between the joists so I never fully investigated. I can now see under the DW and it has its own trap next to the back wall.
  #10 (permalink)
Old 03-29-2012, 02:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you can, disconnect the other end of the drain hose. Make a loop about 24" high and put the hose end in a large bucket. Run the dishwasher to see how it will drain. It will help you to determine if the problem is within the dishwasher or outside.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 Drain trpfn Dishwasher Repair 3 03-23-2012 11:16 PM
Kenmore F02 Drain problem MarpetD Washer Repair 1 02-27-2010 03:40 PM
Kenmore washer won't drain dani252 Washer Repair 1 08-21-2009 07:05 AM
Kenmore 70 did not drain...help! MicheleB6 Washer Repair 3 02-26-2009 05:40 PM
Kenmore won't drain gschone Dishwasher Repair 1 07-05-2008 07:32 PM
