Discuss
Whirlpool Dishwasher not draining
 in
Dishwasher Repair
I have the same issue with dishwasher model GU940 SC GB2. It wan't drain. I found the diagram on your
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Dishwasher not draining
  #61 (permalink)
Old 08-07-2011, 08:27 AM
Junior Member
Milan_45 is on a distinguished road
Question Whirlpool dishwasher wan't drain
I have the same issue with dishwasher model GU940 SC GB2. It wan't drain. I found the diagram on your site and I understand that I need to check the check valve (item 15) but I need some instructions how to do that. Is there a service manual for this dishwasher?
  #62 (permalink)
Old 08-06-2013, 10:20 PM
Junior Member
psltrader is on a distinguished road
Default Fixed it.....
Quote:
Originally Posted by Gene View Post
Check the hose from the air gap to the garbage disposal for a clog. If the garbage disposal has been replaced recently then most likely it was installed improperly. The new garbage disposal comes with the plastic plug in the dishwasher drain connection which has to be removed at time of installation.
Amazing that such a simple thing could could cause this problem!! Thanks..
Phil
  #63 (permalink)
Old 08-08-2013, 08:13 PM
Junior Member
PeterZ is on a distinguished road
Default
Whirlpool dishwasher DU925SCGQ3 not draining after full cycle. Issue resolved by clearing the check valve #15 on pump and motor diagram - thanks Gene!!
  #64 (permalink)
Old 09-01-2013, 01:28 PM
Junior Member
eclyman is on a distinguished road
Default
Thank you Gene! I could jot figure out why water would not drain from my dishwasher, and was prepared to buy a new one. Your post on checking the disposal drain plug was exactly the problem I had. Your minder saved me a few hundred dollars and headache.
  #65 (permalink)
Old 09-12-2013, 08:44 AM
Junior Member
alpastor is on a distinguished road
Default whirlpool DU850SWPQ not draining
I've been reading the posts and this seems very helpful. hoping to get some guidance. I have the above model number which I believe has a soil settler unit on it. just noticed it did not drain this last cycle. there is no air gap. the drain tube connects directly to the drain pipes under a double sink, just before the drain trap. both sinks are draining fine so no blockage there.
where do I start in figuring out why it's not draining? thanks!
  #66 (permalink)
Old 02-15-2015, 07:24 AM
Junior Member
zophini is on a distinguished road
Default Whirlpool Dishwasher will not drain
Hello,
I have a Whirlpool dishwasher du1055xtsb3 and it will not drain. We have replaced the drain pump still will not drain. The water drains straight into the sewer line. It does not do into the disposal. I have pulled off both drain hoses and neither of them look to be clogged. I have ran water through them both and it flow right through. The hose that come off of the dishwasher I tried to run water through it backward and the water did not come out so it looks like the valve is working and not letting the water run back into the dishwasher. We took the assembly apart at the bottom of the inside of the dishwasher and cleaned out a few items like seeds and stuff.. Where the drain hose connects to the main sewer line it looks to be a 1/4" pipe. I put my finger in there and it is clear. The pipe it dumps into is huge. I have not taken it apart to see if it was clogged. It is probably a three to four inch pipe. We have ran the dishwasher multiple times and the water level never rises so I assume most of the water is draining but there is a good one 1/2" to 1" at the bottom. Last evening after rechecking everything I did a rinse cycle and it worked. So I did a full washing and it did not work. I have done rinse cycles in the past and they did not work. I have hit the cancel button multiple times and it will not drain it. I believe that is all that I have done. Any ideas????
  #67 (permalink)
Old 02-21-2015, 04:55 PM
Junior Member
bmgjarvis is on a distinguished road
Default whirlpool dishwasher not draining
I've got a du840swkq0 model whirlpool dishwasher that does not drain. The bottom is full of water at the end of the cycle.
I've cleaned all the drainlines, replaced a drain hose on it, checked the disposal and cleaned that too. There was plastic pieces in the drain basket and what looked like caked up residue from dishwash soap or our hard water in the port to the drainline.
got any suggestions for what else to take apart and check?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not draining RitaH Dishwasher Repair 6 01-27-2010 01:56 AM
Whirlpool Dishwasher Not Draining fiorillo Dishwasher Repair 4 12-10-2009 08:55 AM
Whirlpool Dishwasher Not Draining bsugrad Dishwasher Repair 0 08-12-2009 06:34 PM
Whirlpool dishwasher stop draining dumopz Dishwasher Repair 2 10-16-2008 08:20 AM
Dishwasher not draining Ematt Dishwasher Repair 0 01-24-2008 09:31 AM
