| » Whirlpool Dishwasher not draining |
You are welcome. I'm glad you were able to fix it and it was that simple.
Gene. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Our whirlpool dishwasher is not draining either. Like someone mentioned above, we could push the cancel/drain button and it would drain but now it doesnt even drain when we do that. We have checked for clogs and kinks in the hoses and there is nothing wrong. It is less then 2 years old.
What is the complete model number of the dishwasher?
__________________
Remove the bottom panel and check if the drain pump works when it comes to drain.
If it does not, remove the wires from the drain pump and check for 120 VAC between them while the control calls for drain. If the voltage reading is correct, replace the drain pump. If the voltage reading is incorrect, check the wires between the control board and the drain pump. If the wires are good, replace the control board. - The drain pump Part number: AP3865489 - The control board Part number: AP4303742 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU1055XTSQ3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Gene.
__________________
Model DU810SWPQ0. Will not drain. I have a disposal but its not new and the drains are clear. This problem just started this past weekend. The dishwasher is also making weird noises when it runs that I have not noticed before. May be time for a new one. This one is around 7 years old. Builder put it in, so I am sure it is cheap! I have pulled the bottom panel off but not sure what to do from here. I can push on the big drain line and it makes the water in the dishwasher "gurgle" and move. There is no air trap on top of the sink, but under the sink there is a pipe coming up and it has a vent in the top. I saw alot of posts where check valves were a problem, maybe that is my problem, just no clue where it is. Thanks for the help!
Does it wash?
If it does, then remove the drain hose form wherever it is connected under the sink. Put the end of the hose in a bucket and run the drain cycle to see how it will do it. Post the results. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU810SWPQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com Gene.
__________________
Yes it does wash, but since it will not drain, they are still dirty. I was looking under the sink for the drain line and I did not see it. It should be attached to the disposal, correct? I will look again when I get home, but from looking underneath the dishwasher, it looks like the drain is going down thru the floor.
| Display Modes | |
| Dishwasher not draining | RitaH | Dishwasher Repair | 6 | 01-27-2010 01:56 AM |
| Whirlpool Dishwasher Not Draining | fiorillo | Dishwasher Repair | 4 | 12-10-2009 08:55 AM |
| Whirlpool Dishwasher Not Draining | bsugrad | Dishwasher Repair | 0 | 08-12-2009 06:34 PM |
| Whirlpool dishwasher stop draining | dumopz | Dishwasher Repair | 2 | 10-16-2008 08:20 AM |
| Dishwasher not draining | Ematt | Dishwasher Repair | 0 | 01-24-2008 09:31 AM |
