Discuss
Whirlpool Dishwasher not draining
 in
Dishwasher Repair
Gene Thanks Is there a trick to removing the inlet protector? It seems stuck
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Dishwasher not draining
  #11 (permalink)
Old 02-20-2009, 03:55 PM
Junior Member
PlanoRick is on a distinguished road
Default
  #12 (permalink)
Old 02-20-2009, 04:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thats what it says in the tech sheets: "Rotate screw-end of protector upward to remove part and expose chopper assembly".
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 02-20-2009, 04:42 PM
Junior Member
Default
Thanks that worked. The check valve (#5 on the diagram) was missing the round part. I guess you find my problem. Do I order the part on line of would Sears have this in stock? Should I replace anything else? I did remove the dishwasher and it's sitting in my garage
Thanks again - U da man
  #14 (permalink)
Old 02-20-2009, 05:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome.
The part number for the check valve is AP3152971and it is good in stock. You probably should have it Tuesday. I do not know where do you live and how far is a local Sears store from you.
I can not tell you if anything else has to be replaced. Probably not.
Keep us posted.
__________________
  #15 (permalink)
Old 02-27-2009, 02:09 PM
Junior Member
Default
Gene,
That wan't the problem. What's next?
  #16 (permalink)
Old 02-27-2009, 03:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the drain pump. Remove the drain hose and make sure it's clean. Do not blow air through this hose into the dishwasher.
P.S. Have you replaced the garbage disposal recently?
__________________
  #17 (permalink)
Old 02-27-2009, 04:20 PM
Junior Member
Default
That was it.
  #18 (permalink)
Old 02-27-2009, 04:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check if you removed the plug in the garbage disposal for the dishwasher drain connection.
__________________
  #19 (permalink)
Old 02-20-2010, 06:52 PM
Junior Member
kcdtarheel is on a distinguished road
Default
I had the garbage disposal replaced and now my dishwasher doesn't drain. I called the installer but he said they were unrelated. It seems too conincidental for that to be the case. Is there something I can check/do?
  #20 (permalink)
Old 02-20-2010, 07:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
There is a plug for the dishwasher drain line in the garbage disposal which must be removed during the installation. Disconnect the dishwasher drain hose from the garbage disposal and check if it was removed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher not draining RitaH Dishwasher Repair 6 01-27-2010 01:56 AM
Whirlpool Dishwasher Not Draining fiorillo Dishwasher Repair 4 12-10-2009 08:55 AM
Whirlpool Dishwasher Not Draining bsugrad Dishwasher Repair 0 08-12-2009 06:34 PM
Whirlpool dishwasher stop draining dumopz Dishwasher Repair 2 10-16-2008 08:20 AM
Dishwasher not draining Ematt Dishwasher Repair 0 01-24-2008 09:31 AM
