Discuss
Dishwasher did not drain, no lights on front panel
 in
Dishwasher Repair
Dishwasher did not drain. Breaker/quad outlet all OK so Power is fine. Drain is not plugged. The front panel is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher did not drain, no lights on front panel
  #1 (permalink)
Old 01-15-2008, 12:50 PM
JDE JDE is offline
Junior Member
JDE is on a distinguished road
Default Dishwasher did not drain, no lights on front panel
Model Number: KUDI01TJBT0   Brand: Kitchen Aid   Age: 1 - 5 years
Dishwasher did not drain. Breaker/quad outlet all OK so Power is fine. Drain is not plugged. The front panel is dead - no lights at all. Open and closed door, no change. Checked overflow switch - appears to be fine but may short across it just to make sure it is not blocking power with open switch. Checked schematic and does not appear drain overflow switch could shut off power. I suspect the door switch might have failed. Seems unlikely while it was running but ???? who knows. Did not find any kind of reset button on pump motor. Schematic shows something called a TCO in drain circuit wiring -maybe the control circuit. If I trace the wires, maybe I could short the door switch and see if the pump motor starts up???? Not sure I can find the right wires. Shows wire color as "T" and "B-W" - I know black white but T is ???? Looks like door switch for this kitchen aid is behind the stainless steel interior front panel with lots of screws.
Ads By Google
Related Models
Whirlpool KUDI01TJBT0 Undercounter Dishwasher
Whirlpool KUDI01TJBT1 Undercounter Dishwasher
Whirlpool KUDI01TJWH0 Undercounter Dishwasher
Whirlpool KUDI01TJWH1 Undercounter Dishwasher
Whirlpool KUDI02CRBL0 Undercounter Dishwasher
Whirlpool KUDI02CRBL1 Undercounter Dishwasher
Whirlpool KUDI02CRBL2 Undercounter Dishwasher
Whirlpool KUDI02CRBL3 Undercounter Dishwasher
Whirlpool KUDI02CRBL4 Undercounter Dishwasher
Whirlpool KUDI02CRBS0 Undercounter Dishwasher
Whirlpool KUDI02CRBS1 Undercounter Dishwasher
Whirlpool KUDI02CRBS2 Undercounter Dishwasher
Whirlpool KUDI02CRBS3 Undercounter Dishwasher
Whirlpool KUDI02CRBS4 Undercounter Dishwasher
Whirlpool KUDI02CRWH0 Undercounter Dishwasher
Whirlpool KUDI02CRWH1 Undercounter Dishwasher
Whirlpool KUDI02CRWH2 Undercounter Dishwasher
Whirlpool KUDI02CRWH3 Undercounter Dishwasher
Whirlpool KUDI02CRWH4 Undercounter Dishwasher
Whirlpool KUDI02FRBL0 Undercounter Dishwasher
Whirlpool KUDI02FRBL1 Undercounter Dishwasher
Whirlpool KUDI02FRBL2 Undercounter Dishwasher
Whirlpool KUDI02FRBL3 Undercounter Dishwasher
Whirlpool KUDI02FRBL4 Undercounter Dishwasher
Whirlpool KUDI02FRSS0 Undercounter Dishwasher
Whirlpool KUDI02FRSS1 Undercounter Dishwasher
Whirlpool KUDI02FRSS2 Undercounter Dishwasher
Whirlpool KUDI02FRSS3 Undercounter Dishwasher
Whirlpool KUDI02FRSS4 Undercounter Dishwasher
Whirlpool KUDI02FRWH0 Undercounter Dishwasher
Whirlpool KUDI02FRWH1 Undercounter Dishwasher
Whirlpool KUDI02FRWH2 Undercounter Dishwasher
Whirlpool KUDI02FRWH3 Undercounter Dishwasher
Whirlpool KUDI02FRWH4 Undercounter Dishwasher
Whirlpool KUDI02IRBL0 Undercounter Dishwasher
Whirlpool KUDI02IRBL1 Undercounter Dishwasher
Whirlpool KUDI02IRBL2 Undercounter Dishwasher
Whirlpool KUDI02IRBL3 Undercounter Dishwasher
Whirlpool KUDI02IRBL4 Undercounter Dishwasher
Whirlpool KUDI02IRBS0 Undercounter Dishwasher
Whirlpool KUDI02IRBS1 Undercounter Dishwasher
Whirlpool KUDI02IRBS2 Undercounter Dishwasher
Whirlpool KUDI02IRBS3 Undercounter Dishwasher
Whirlpool KUDI02IRBS4 Undercounter Dishwasher
Whirlpool KUDI02IRBT0 Undercounter Dishwasher
Whirlpool KUDI02IRBT1 Undercounter Dishwasher
Whirlpool KUDI02IRBT2 Undercounter Dishwasher
Whirlpool KUDI02IRBT3 Undercounter Dishwasher
Whirlpool KUDI02IRBT4 Undercounter Dishwasher
Whirlpool KUDI02IRWH0 Undercounter Dishwasher
Whirlpool KUDI02IRWH1 Undercounter Dishwasher
Whirlpool KUDI02IRWH2 Undercounter Dishwasher
Whirlpool KUDI02IRWH3 Undercounter Dishwasher
Whirlpool KUDI02IRWH4 Undercounter Dishwasher
Whirlpool KUDI210S0
Whirlpool KUDI21DS0
Whirlpool KUDI21DS1
Whirlpool KUDI21DS2
Whirlpool KUDI21DS3
Whirlpool KUDI21SS1
Whirlpool KUDI21SS2
Whirlpool KUDI220T0
Whirlpool KUDI220T1
Whirlpool KUDI220T2
Whirlpool KUDI220T3
Whirlpool KUDI220T4
Whirlpool KUDI220T5
Whirlpool KUDI220T6
Whirlpool KUDI220WWH0
Whirlpool KUDI220WWH1
Whirlpool KUDI220WWH2
Whirlpool KUDI220WWH3
Whirlpool KUDI220WWH4
Whirlpool KUDI22GT0
Whirlpool KUDI22GT1
Whirlpool KUDI22GT2
Whirlpool KUDI22GT3
Whirlpool KUDI22HT0
Whirlpool KUDI22HT1
Whirlpool KUDI22HWWH0
Whirlpool KUDI22HWWH1
Whirlpool KUDI22XX0
Whirlpool KUDI22XX1
Whirlpool KUDI22XX2
Whirlpool KUDI230B0
Whirlpool KUDI230BAL0
Whirlpool KUDI230BW0
Whirlpool KUDI230BWH0
Whirlpool KUDI23HB0
Whirlpool KUDI23HBWH0
Whirlpool KUDI24SEAL0
Whirlpool KUDI24SEAL1
Whirlpool KUDI24SEAL2
Whirlpool KUDI24SEAL3
Whirlpool KUDI24SEAL4
Whirlpool KUDI24SEAL5
Whirlpool KUDI24SEBL0
Whirlpool KUDI24SEBL1
Whirlpool KUDI24SEBL2
Whirlpool KUDI24SEBL3
Whirlpool KUDI24SEBL4
Whirlpool KUDI24SEBL5
Whirlpool KUDI24SEWH0
Whirlpool KUDI24SEWH1
Whirlpool KUDI24SEWH2
Whirlpool KUDI24SEWH3
Whirlpool KUDI24SEWH4
Whirlpool KUDI24SEWH5
Whirlpool KUDI25CHAL0
Whirlpool KUDI25CHBL0
Whirlpool KUDI25CHBL1
Whirlpool KUDI25CHBS0
Whirlpool KUDI25CHBT0
Whirlpool KUDI25CHBT1
Whirlpool KUDI25CHWH0
Whirlpool KUDI25CHWH1
Whirlpool KUDJ01TJBL0 Undercounter Dishwasher
Whirlpool KUDJ01TJBL1 Undercounter Dishwasher
Whirlpool KUDJ01TJBT0 Undercounter Dishwasher
Whirlpool KUDJ01TJBT1 Undercounter Dishwasher
  #2 (permalink)
Old 01-15-2008, 07:22 PM
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
Some models have an internal fuse up inside the control panel to the right of the door switch. It does not resemble a fuse at all. It looks like a white square box with two wires going to it. TURN BREAKER OFF FOR DISHWASHER. You will have to remove the inner door panel to gain access. Join the wires temporarily, reassemble and close the door. If everthing works that fuse need replacing. Just something simple for you to check to help you out.
  #3 (permalink)
Old 01-16-2008, 02:24 PM
JDE JDE is offline
Junior Member
Default
Quote:
You did hit the nail on the head on this one. Removed that upper control panel (plastic pops right off with 4 screws), found the white fuse or what appeared to be what you described, pulled connectors and put it on the ohm meter - wide open connection (no continuity). Soldered a wire over it for now, machine worked fine. I think a piece of food got into pump and may have overloaded it very briefly - works fine now and ordering the new fuse as we speak. Thanks so much for your help - you obviously have very good diagnostic skills and knowledge to boot!!!
  #4 (permalink)
Old 01-16-2008, 03:48 PM
Senior Expert
APP Volunteer
Default
If I could only convince my wife how smart I am, maybe we would get along better LOL.
Glad I could help.
  #5 (permalink)
Old 01-25-2008, 11:05 AM
Junior Member
supawiz6991 is on a distinguished road
Unhappy Weird Dish washer
When i try to turn on my dish washer it makes a humming sound and the heating coil in the bottom heats up. Other than that it doesnt do anything. no water nothing. I checked the water shut off and it is open so i dont know what the deal is.
  #6 (permalink)
Old 01-25-2008, 07:47 PM
Senior Expert
APP Volunteer
Default
I need the make and model number to be able to help you out. Thanks.
  #7 (permalink)
Old 01-26-2008, 01:35 PM
Junior Member
Spencer8821 is on a distinguished road
Default
Hey this is supawiz6991 i couldnt get on my other name so here i am but. the dishwasher in question is a GE Potscrubber800 there was some numbers on the inside sticker of the door i dont know if you need them but they are gsd830tww/gsd800tba. Thanks for the help!
  #8 (permalink)
Old 01-27-2008, 07:45 AM
Senior Expert
APP Volunteer
Default
Sounds to me like your motor is stuck. With the door unlatched, remove the lower kick plate. Get a flat blade screwdriver and on the end of the motor you will see some fins (for cooling) (not sure how to describe them) try turning the motor with the screwdriver by appling pressure to those fins to turn the motor. There is not a lot of room to move the fins. If they dont turn or only move a little the motor is stock and you will have to keep pressure on them and walk them around until the motor turns free. It's kind of hard to describe what to do on the P.C as I've done tons of these for stuck motors. Hope this helps.
  #9 (permalink)
Old 01-27-2008, 12:15 PM
Junior Member
Thumbs up Good and bad
You were right about the pump it was stuck. Now that it is unstuck it runs good but still no water. I checked the water shut off and it is open. I will pull a pipe apart and see if there is water but do you have any idea what else could be worng?
  #10 (permalink)
Old 01-27-2008, 01:48 PM
Senior Expert
APP Volunteer
Default make sure you are getting water to the dishwasher!!!
Check float and switch to make sure it moves up and down freely. A float stuck in the up position will prevent water from entering. Next cycle the timer (if it's mechanical) and make sure you don't turn past the fill. It's easy to miss the fill when advancing the timer. Last thing is a possible bad water valve.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no lights on front panel tom benz Dryer Repair 1 02-16-2010 06:06 PM
Dishwasher: does not work, no lights in control panel anis74us Dishwasher Repair 0 02-14-2010 04:09 PM
Display lights out on Front Panel sgdavis Refrigerator & Freezer Repair 0 06-04-2009 07:53 PM
Kenmore Dishwasher no lights on panel rjohnsonpcss Dishwasher Repair 1 02-13-2009 02:17 PM
Frigidaire Dishwasher Control Panel No Lights thom2 Dishwasher Repair 0 12-12-2008 03:29 PM
