Discuss
Leaking after washer is turned on
 in
Dishwasher Repair
Hi All, I need help identifying which parts to purchase. I have a 2 year old washer that just leak
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leaking after washer is turned on
  #1 (permalink)
Old 01-14-2008, 05:41 PM
JohnMathapha JohnMathapha is offline
Junior Member
JohnMathapha is on a distinguished road
Default Leaking after washer is turned on
Model Number: FP0509208   Brand: Whirlpool   Age: 1 - 5 years
Hi All,
I need help identifying which parts to purchase. I have a 2 year old washer that just leak from the bottom when it's running. I've checked the drainage and inlet line and it's ok. I looked underneath the washer and notice water was leaking from middle of the tub. I think it's the sump pump gasket or the volute seal. Any suggestion?
Also, what's a sump tab and what does it do or suppose to do?
Any help would be appreciated....
John
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 05:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi John,
In order to provide the most accurate advise I need the complete model number of the dishwasher. The number you posted is the serial number.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-15-2008, 06:08 PM
Junior Member
Default Model #
model: GU1200XTLS1
serial #: FP0509208
  #4 (permalink)
Old 01-16-2008, 11:09 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
A sump tab is a part of a locking mechanism.
Both parts you mentioned could cause a water leak. The best thing is to remove the dishwasher from the cabinet to find out which part is wrong exactly.
- Here are the break down diagrams for the Whirlpool dishwasher Model GU1200XTLS1
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking Washer GREGG GEE Washer Repair 1 11-29-2007 02:39 PM
leaking washer Michelle Washer Repair 3 10-20-2007 06:44 AM
Freezer frosted up after I turned power off tmadams Refrigerator & Freezer Repair 3 10-10-2007 03:19 AM
Milk and water freezing temp turned down. thermostat? bidd1 Refrigerator & Freezer Repair 1 08-11-2007 04:36 PM
fan does not rotate when turned on so no cold air comes out just alot of noise SKEET21 Heating, Ventilation, and Air Conditioning (HVAC) 1 08-03-2007 11:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
