Discuss
Bosch Dishwasher shutting off and tripping GFI
 in
Dishwasher Repair
Starting last night the dishwasher ran for a bit and kicked off. I opened it up because I thought I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher shutting off and tripping GFI
  #1 (permalink)
Old 03-16-2012, 07:10 PM
Junior Member
ChadWilliam1 is on a distinguished road
Default Bosch Dishwasher shutting off and tripping GFI
Model Number: she43mo2uc/50   Brand: Bosch   Age: 1 - 5 years
Starting last night the dishwasher ran for a bit and kicked off. I opened it up because I thought I forgot to turn it on so I was going to add detergent well I noticed a dirty bowl I put in it was upside down and full of water. Then I realized i already added the detergent. I closed it up and tried to turn it on. Well It would not turn on, turns out it tripped the GFI under the sink.
Now when I run it, it kicks on for about 10 seconds and shuts off tripping the GFI. No error code or anything. My initial thought is the drain pump is bad. I dont think the 110 going to the washing machine is shorting because it turns on also there is no leaks and it had been installed 3 years. I installed it (I also plugged it in to another outlet and it still tripped so the GFI is not the issue)
I just wanted advice on what to check first before I pull this thing apart. I just replaced the drain screen two weeks ago the other one was getting clogged up. I removed the screen today to see if I could see anything clogging it but it appeared fine.
Chad
Ads By Google
Related Models
Whirlpool SHF3800W0
Whirlpool SHF3800W1
Whirlpool SHF3801W0
Whirlpool SHF3804W0
Whirlpool SHF3804W2
Whirlpool SHF4500W0
Whirlpool SHF5500W0
Whirlpool SHF5501W0
Whirlpool SHF5504W0
Whirlpool SHF5584P0
Whirlpool SHF5584P1
Whirlpool SHF5584P2
Whirlpool SHF5800W0
Whirlpool SHF5800W1
Whirlpool SHF5801W0
Whirlpool SHF5801W1
Whirlpool SHF5880P0
Whirlpool SHF5884P0
Whirlpool SHF5884P1
Whirlpool SHF5884P2
Whirlpool SHF6000W0
Whirlpool SHF6000W1
Whirlpool SHF6002W0
Whirlpool SHF7800W0
Whirlpool SHF7800W1
Whirlpool SHF7801W0
Whirlpool SHF7804W0
Whirlpool SHF7804W1
Whirlpool SHF7884P0
Whirlpool SHF7884P1
Whirlpool SHF7884P2
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30000
Whirlpool SHU30010
Whirlpool SHU30011
Bosch SHU3002
Whirlpool SHU30040
Whirlpool SHU30041
Bosch SHU3006
Whirlpool SHU30110
Bosch SHU3012
Whirlpool SHU30140
Whirlpool SHU30141
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
  #2 (permalink)
Old 03-17-2012, 09:04 AM
Junior Member
Default
Update. I got it to run by plugging it into a non GFI plug using an ext cord.
My guess is either the drain pump is dirty,clogged or broken. I ran a quick wash and it is not draining. I disconnected the hose and ran it to a bucket so I can see how much is draining.
After doing some reading I went up and bought some CLR from the Store and put a cup of that in to see if that clears and debris out from the pump before I take the pump out and clean it.
  #3 (permalink)
Old 03-17-2012, 06:54 PM
Junior Member
Default
Update
Checked the drain pump and check valve. I removed the drain pump and it fired right up and had plenty of power. Check valve moved freely, checked the circulation motor and that also fired right up. Plugged everything in while it was upside down and that also worked fine. I even plugged i back into the original GFI and it turned right on and this is the GFI that was originally tripping when I ran the washing machine for 10 seconds.
Well I put everything back together and ran it again. The whole bottom of the washing machine below the tub filled up with water. So this tells me that was what was causing the GFI to trip. This unit has an overflow safety so that if the water level under the tub fills up with water it will shut off the water valve.
Well I finnally shut it off and filled it back over and took everything back apart. My father in law came over and we raced the source of the leak back to the Oring on the main circulation pump. We pulled it apart cleaned the Oring which had hard water deposits on it and put it back together. So far i think I have it resolved but I am still waiting on the washer to finish running.
Its not tripping a GFI and its running but in the middle of the kitchen.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher nomadx4 Dishwasher Repair 0 02-15-2012 06:42 PM
dishwasher tripping house breaker slvrpkr Dishwasher Repair 0 10-09-2010 12:01 PM
Bosch dishwasher tripping breaker Aardvark! Dishwasher Repair 0 06-10-2010 05:37 AM
Maytag dishwasher tripping gfi outlet cbkal Dishwasher Repair 1 04-16-2009 06:25 PM
Bosch dishwasher sherryg Dishwasher Repair 0 10-08-2007 10:46 AM
