Discuss
Whirlpool not draining
 in
Dishwasher Repair
My whirlpool dishwasher is not draining (model s62nxplp-7653). I checked the hose and did not find a blockage. When I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool not draining
  #1 (permalink)
Old 03-16-2012, 12:02 PM
Junior Member
tops1965 is on a distinguished road
Default Whirlpool not draining
Brand: Whirlpool   Age: 1 - 5 years
My whirlpool dishwasher is not draining (model s62nxplp-7653). I checked the hose and did not find a blockage. When I disconnected the hose from the pump the remaining water drained out so I dont think it is blocked internally. When I push the drain/cancel button the motor hums for a few seconds then clicks and shuts off. I paid $300 for the machine 3 yrs ago and a service call is gonna run me about $250 so I dont think it makes sense to go that route. Any ideas? I really appreciate the help.
John
Ads By Google
  #2 (permalink)
Old 03-16-2012, 07:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
The model number you posted is incorrect. Verify and repost it please. The name plate should be on the door frame.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-17-2012, 06:49 AM
Junior Member
Default
OK, I think it is DU945PWSQ0. Thanks!
  #4 (permalink)
Old 03-17-2012, 04:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the problem is a clogged check valve (the piece where the drain hose is connected to at the pump). It is shown as #15 at the diagram. Unscrew the check valve and check it inside.
- The check valve Part number: AP2910020
Here are the breakdown diagrams and Replacement parts for Whirlpool DU945PWSQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
__________________
  #5 (permalink)
Old 03-17-2012, 05:26 PM
Junior Member
Default
I did that. The check valve was fine. What alarms me is when I push the cancel/drain button the motor hums for a few seconds, clicks and shuts off without draining any water. Is it possibly the solenoid? Thanks for the help.
  #6 (permalink)
Old 03-17-2012, 05:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by tops1965 View Post
...when I push the cancel/drain button the motor hums for a few seconds, clicks and shuts off without draining any water. Is it possibly the solenoid?...
There are no solenoids. The motor has the overload protection which makes such clicking sound.
If there are any water marks on the motor, it had a slow water leak for some time, which caused damage to the motor bearings and/or windings.
If there are no such marks, then remove the top parts from the pump and check for a foreign objects inside and/or broken impellers.
Post the results.
__________________
  #7 (permalink)
Old 03-17-2012, 07:00 PM
Junior Member
Default
Can I access the top of the pump from inside the machine or do I need to get at it from below?
  #8 (permalink)
Old 03-17-2012, 07:42 PM
Junior Member
Default
Gene, I was able to take off the pump cover (no14) and the screw and seal (no12) but for the life of me I cant figure how to get the impeller cover off. When I try to turn it with a vice grip it feels like its turning the motor. There must be a hex underneath I need to grip to get it off?
  #9 (permalink)
Old 03-19-2012, 02:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Which part did you call "impeller cover"? Can you refer to the numbers at the diagram?
__________________
  #10 (permalink)
Old 03-19-2012, 02:52 PM
Junior Member
Default
That would be no 11.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Not Draining dmsokol99 Dishwasher Repair 0 05-16-2011 08:07 AM
Whirlpool Dishwasher Not Draining pgonza02 Dishwasher Repair 0 04-26-2010 02:29 PM
Whirlpool not draining thoffland Dishwasher Repair 1 04-26-2010 02:02 PM
Whirlpool Dishwasher Not Draining fiorillo Dishwasher Repair 4 12-10-2009 08:55 AM
Whirlpool Dishwasher Not Draining bsugrad Dishwasher Repair 0 08-12-2009 06:34 PM
