hi my control board failed burnt at 4 wire conector, the washer worked but you could smell the board burning then it quit. i replaced the control board with your updated part and it ran for most of the cycle ok , but did not drain completly and when i went to use it agian it wont function, no power ifound the fuse that clips on the board box blown. i need a diagram to test the wiring and components or your best advise please i didf cut off and replace 2 of the terminals in the 4 wire conector to get a good tight fit
