Discuss
Maytag dishwasher
 in
Dishwasher Repair
The lower spray arm appears to be clogged. Should I replace it or try to take it off and clean
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag dishwasher
  #1 (permalink)
Old 01-14-2008, 11:48 AM
BeckyNTulsa BeckyNTulsa is offline
Junior Member
BeckyNTulsa is on a distinguished road
Default Maytag dishwasher
Model Number: mdb4040awb   Brand: Maytag   Age: 5 - 10 years
The lower spray arm appears to be clogged. Should I replace it or try to take it off and clean it out? How do I get it loose. Are there any other pieces connected with it that should be replaced or cleaned
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-14-2008, 08:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Becky,
To remove the lower spray arm you have to unscrew the spray arm cap (#34 on the pump & motor break down diagram) first.
I would recommend to replace it instead of cleaning because it's not expensive part.
Also I would recommend to remove the pump cover (#4 on the pump & motor break down diagram) and check the pump housing filter (#6 on the pump & motor break down diagram) and the rinse arm assembly (#7 on the pump & motor break down diagram).
If they are clogged, it's better to replace them too.
- The part number for the lower spray arm is AP178746
- The part number for the pump housing filter is AP2644606
- The part number for the rinse arm assembly is AP403589
Here are the break down diagrams for the Maytag dishwasher Model MDB4040AWB
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-14-2008, 08:26 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
Great advice Gene, but we should also mention that the spray holes on all maytag dishwashers are very tiny and plug up very easily. If the bottom ones plugged, chances are the other one or two will be plugged also.
So just goes to show you RINSE RINSE RINSE those dishes and everyone could save themeselves many dishwasher headaches.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag dishwasher not working at all .. rtc Dishwasher Repair 5 01-04-2008 06:19 PM
Maytag dishwasher won't cycle anotherproject Dishwasher Repair 0 12-09-2007 12:56 PM
Maytag dishwasher T Sefchick Dishwasher Repair 0 11-13-2007 10:02 AM
maytag dishwasher rschem Dishwasher Repair 3 11-09-2007 01:56 PM
Maytag dishwasher on the blink Sandra Dishwasher Repair 0 10-21-2007 11:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
