Im not quite sure how old this is but it is in good condition and was washing a load it started bumping all over I shut it off and then the spin cycle wouldnt work. Took the front off the washer and belt was fine decided to hold the lid switch while washer was on and will spin if I hold the switch down but not if the lid is down...how can i fix this?
