Discuss
Dishwasher does not dry the dishes
 in
Dishwasher Repair
The dishwasher is not drying the water from the dishes. I am a Master Tech for GM and can diagnose
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher does not dry the dishes
  #1 (permalink)
Old 01-13-2008, 06:31 PM
masterteck4gm masterteck4gm is offline
Junior Member
masterteck4gm is on a distinguished road
Default Dishwasher does not dry the dishes
Model Number: FDB2810LDC1   Brand: Frigidaire   Age: 1 - 5 years
The dishwasher is not drying the water from the dishes. I am a Master Tech for GM and can diagnose this but I do not have a manual. What should the ohms be across the element? Is there a thermostat or something to turn it on? Please help as a baby is here and funds are to tight to call in a repairman. Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-13-2008, 06:59 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
Was the dishwasher drying ok before??
I do believe the frigidaire dishwashers have a small bi-metal thermostat located on the bottom of the tub that if it opens it would stop the heater from coming on. Have not seen many heating element failures in the 18 years of fixing appliances. Thermostat is black and silver with two wires going to it.
  #3 (permalink)
Old 01-14-2008, 07:34 AM
Junior Member
Default
Ripley's,
Do I just use an ohmmeter,(Fluke 87), to check the thermostat? The Frigidaire website says it is a re-setting type thermostat. How do I check the operation of this type? Thanks
Rob
  #4 (permalink)
Old 01-14-2008, 09:02 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
also check water hardness ... make sure you only use 1 tblsn of detergent .. also, MUST USE JET DRY ( or any rinse agent, put it in the dispenser and set accordingly ... ) also, should NOT pre-rinse your dishes before putting them in the d/w .. use the Rinse/Hold cycle instead of pre-rinsing in the sink ...
__________________
regards
jim
  #5 (permalink)
Old 01-14-2008, 09:30 AM
Junior Member
Default Testing the "re-setting" style thermostat
But how do I test the re-setting type thermostat? Can I test it without the dishwasher running? Is the thermostat "normally closed" when in an idle state? If so, then when it "opens", is that when the element is not energized? If that is the case, then I should have resistance when the dishwasher is not operating correct? I think it is the thermostat, but I just need guidance on how to test it properly.
Thanks, Masterteck4gm
  #6 (permalink)
Old 01-14-2008, 05:51 PM
Junior Member
Thumbs up High Temp Thermostat
Thanks Ripley's,
I checked the Thermostat and it is open. It had burnt one of the terninal connectors, but I will rewire a new one on when I install the T-Stat. Thanks for your help.
Masterteck4gm
  #7 (permalink)
Old 01-14-2008, 06:55 PM
Senior Expert
APP Volunteer
Default
Glad I could at least point you in the right direction. Good luck on your repair.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishes not getting clean Tony W Dishwasher Repair 1 07-16-2008 08:53 AM
black spots on dishes from ge dishwasher bruce921 Dishwasher Repair 1 12-31-2007 06:26 AM
Washing dishes lsternberg Dishwasher Repair 0 11-20-2007 09:39 AM
dishwasher not spraying dishes SPUD Dishwasher Repair 1 10-23-2007 03:48 AM
dishes not clean feinerl Dishwasher Repair 5 10-22-2007 08:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
