| » Dishwasher does not dry the dishes |
Model Number: FDB2810LDC1 Brand: Frigidaire Age: 1 - 5 years
The dishwasher is not drying the water from the dishes. I am a Master Tech for GM and can diagnose this but I do not have a manual. What should the ohms be across the element? Is there a thermostat or something to turn it on? Please help as a baby is here and funds are to tight to call in a repairman. Thanks
Was the dishwasher drying ok before??
I do believe the frigidaire dishwashers have a small bi-metal thermostat located on the bottom of the tub that if it opens it would stop the heater from coming on. Have not seen many heating element failures in the 18 years of fixing appliances. Thermostat is black and silver with two wires going to it. |
also check water hardness ... make sure you only use 1 tblsn of detergent .. also, MUST USE JET DRY ( or any rinse agent, put it in the dispenser and set accordingly ... ) also, should NOT pre-rinse your dishes before putting them in the d/w .. use the Rinse/Hold cycle instead of pre-rinsing in the sink ...
__________________
regards jim |
But how do I test the re-setting type thermostat? Can I test it without the dishwasher running? Is the thermostat "normally closed" when in an idle state? If so, then when it "opens", is that when the element is not energized? If that is the case, then I should have resistance when the dishwasher is not operating correct? I think it is the thermostat, but I just need guidance on how to test it properly.
Thanks, Masterteck4gm |
| Display Modes | |
| dishes not getting clean | Tony W | Dishwasher Repair | 1 | 07-16-2008 08:53 AM |
| black spots on dishes from ge dishwasher | bruce921 | Dishwasher Repair | 1 | 12-31-2007 06:26 AM |
| Washing dishes | lsternberg | Dishwasher Repair | 0 | 11-20-2007 09:39 AM |
| dishwasher not spraying dishes | SPUD | Dishwasher Repair | 1 | 10-23-2007 03:48 AM |
| dishes not clean | feinerl | Dishwasher Repair | 5 | 10-22-2007 08:07 PM |
