Discuss
Dishwasher not heating (element/thermostat good)
 in
Dishwasher Repair
Hi, Recently, the heating element blew when a fork landed on it while it was heating and caused it to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher not heating (element/thermostat good)
  #1 (permalink)
Old 01-12-2008, 02:43 PM
jkordzi jkordzi is offline
Junior Member
jkordzi is on a distinguished road
Default Dishwasher not heating (element/thermostat good)
Model Number: MDB6650AWW   Brand: Maytag   Age: 1 - 5 years
Recently, the heating element blew when a fork landed on it while it was heating and caused it to crack. I replaced it but it doesn't get power at any time during the cycle. The hi-limit thermostat has continuity. I can use a DVOM and solder and I've had the control board out before for another issue, so if it's the control board, I'd appreciate specific trouble shooting directions. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-13-2008, 03:36 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Per the schematic, check the control board output pin that supplies voltage to the heater. If no voltage=bad board. You might want to check for a fused open ribbon on the board.
__________________
  #3 (permalink)
Old 01-20-2008, 07:03 PM
Junior Member
Default
Finally got around to doing the repair. The back of the board had a fused ribbon like you said. Bypassed it by soldering a short piece of insulated wire across the fused section, but still didn't work so will get a new board - must have blown one or more of the solid state components on the board. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No bake, element appears good jreynolds Oven Repair (including Ranges and Cooktops) 5 12-21-2007 12:21 PM
Dishwasher Heating element issue jfk0204 Dishwasher Repair 0 11-30-2007 01:59 PM
Replacing thermostat on Kenmore Dishwasher wbstrs1 Dishwasher Repair 2 09-20-2007 03:52 AM
Dishwasher heating element replace Terence J. Douglas Dishwasher Repair 1 09-18-2007 08:52 PM
Kenmore dishwasher thermostat help wbstrs1 Dishwasher Repair 1 09-16-2007 03:53 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
