Discuss
Water is cold & will not drain from tub
 in
Dishwasher Repair
Water is cold during the wash and rinse cycle. Water will not drain from the tub, so when cycle is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Water is cold & will not drain from tub
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
LinkBack (1) Thread Tools Search this Thread Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 01-11-2008, 04:45 PM
CELESTE RC CELESTE RC is offline
Junior Member
CELESTE RC is an unknown quantity at this point
Default Water is cold & will not drain from tub
Model Number: 1004967   Brand: Whirlpool   Age: 1 - 5 years
Water is cold during the wash and rinse cycle. Water will not drain from the tub, so when cycle is complete the dishwasher is full of water.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-11-2008, 07:15 PM
fyxer fyxer is offline
Junior Member
fyxer is on a distinguished road
Default water cold & will not drain from tub
If the water in the dishwasher is cold, your dishwasher is hooked up to the cold water pipe instead of the hot water,the heater in the dishwasher is not on during the wash cycle, hot water coming in the dishwasher is usually a little over 100 degrees,on some models with--sanitizer--settings it might ask for about 140 degrees, in this situation the heater will turn on and further heat the water to the desired degree before the wash begins----
The water will not drain, this can be caused by a blocked drain,or a new disposal installed.
  #3 (permalink)
Old 01-14-2008, 03:45 PM
Junior Member
Default dishwasher
The dishwasher has been installed and working fine for almost 5 years, so the hot and cold water hookups are correct. I checked for a clogged drain first thing. I though this was a site for homeowners to air their appliance issues or problems and receive help or suggestions with repairs.
  #4 (permalink)
Old 01-15-2008, 12:40 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Celeste, as Ripleys so correctly pointed out in your other question, it helps to be a little polite when asking for help, especially since it's free. Both Fyxer and Ripley had posted good explanations and solutions to both your dishwasher and cooktop problems and gave you ideas on what to check. It is pretty difficult to diagnose an appliance repair problem over the internet, and a lot depends on the information provided by the person asking the question. Very often you would be given several things to check in order to isolate the cause of the problem and you may have to communicate back and forth with the person helping you in doing so. So what I'm saying is, a little patience, politeness, and understanding goes a long way... if you are truly looking for help that is.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/4313-water-cold-will-not-drain-tub.html
Posted By For Type Date
Digg - Water is cold & will not drain from tub This thread Refback 01-18-2008 02:56 AM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no cold water alone coming in .do get hot or warm. so cold must be comin through valv misterfixall Washer Repair 1 11-16-2007 12:51 PM
Problem with cold water coming in kdickins Washer Repair 0 10-03-2007 01:11 PM
No cold water josephl Washer Repair 0 09-21-2007 05:42 PM
cold water overflows notsure Washer Repair 4 09-12-2007 06:04 AM
Cold water connection honeycreek Washer Repair 0 09-01-2007 08:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
