I have exactly the same problem as posted yesterday by ed3120. when I press buttons they come on but when I press start they go off. The only button that works is the cancel/drain. that one will work. Do I have to replace the entire circuit board to fix this problem or is there a cheaper way??? thanks, Donaldwo dwwsr01@aol.com
