teetime
#1 Posted : Monday, August 3, 2009 5:39:40 PM(UTC)
teetime
This is my second trip to this forum with this dishwasher. Recently, the dishwasher will trip its house circuit breaker when I fully open the dishwasher door.
When the door reaches the fully open position I will see a spark at or near the right side door hinge. I stopped using the dishwasher and today (after several days of no use) I pulled off the door panel. I don't see any obvious causes for the sparking, nor can I see where it originated. I do notice some kind of sensor located in the vicinity of the right door hinge. I can't find any technical information about this dw online, but I perhaps this is a sensor to turn off the water flow if the level reaches this height (?).
After reassembling the dw, I turned on the power and opened the door - no spark. Maybe the original problem was caused by water in the door, but there is none there now.
I am going to try running it with water tomorrow, but before I do that I thought I would check here to see if there is a known problem that could cause this.
Thanks,
Jerry
teetime
#2 Posted : Tuesday, August 4, 2009 11:58:30 AM(UTC)
teetime
I found the problem. The pulley wire for the door counterbalance had rubbed through the insulation for the main power wire for the dishwasher. It was easily seen when I removed the front door panel, ran the dishwasher, then opened the door after the cycle ended.
#3 Posted : Tuesday, August 4, 2009 6:00:18 PM(UTC)
Glad to hear you were able to find and fix the problem. Thank you for sharing it with us and good luck with your dishwasher.
